LCD from ctx ez book
  • LCD from ctx ez book
    I took apart a notebook that wasn't useable anymore to get the LCD screen out of it...Im a total newbie and I don't want to mess this up too bad so I had some questions.
    1. There is a silver sheet on the back of the lcd...anyone know what this does?
    2. I looked on the net for this lcd (sharp lm64c35p), I can't find much information on these. Can someone point me in the right direction.
    3. Would the lcd controller be inside the notebook case or attached to the lcd screen.
    thanks a bunch.
    if you need some pictures i can get those too.
    CuzFu
    This has all been discussed before, so use the search function for a more detailed description. The Laptop LCD will need a separate controller as they are built into the motherboard. This controller can cost upwards of $300 (ouch!) so check out www.earthlcd.com for a rough guide. As far as I know, there is no way to get the controller off the laptop motherboard - I have a pc chips controller on a laptop which I can't use for this reason. If the metal sheet is on the laptop's plastic and not part of the actual screen module it could be insulation or grounding or something - I wouldn't really worry about it. Unless you can get hold of a rubble controller it probably isnt worth using your laptop screen. Bummer.
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
