no video files on liliput
  • no video files on liliput
    Hello
    I get my liliput touch screen from mp3car the last week and I just was testing I conected the t-screen to my laptop everything is fine but when I try to play a movie file on windows m player .avi .mpg etc. I can see the movie on my laptop monitor but on the touch screen the media player windows is black. nothing display on it. I was looking at the setings change some of them but nothing.
    I hope some body here knows what it is and help me out, if u ask I can put pictures.
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
    I think it might have something to do with your primary display. In my experience I've noticed that if you set the external screen as the "primary" display it will show the videos. Depending on your video card and software though, you can adjust the settings so that you can have video on both. Since your only testing this out though, I think you probably dont have to worry because i'm sure if you hook it up directly to a computer it should play fine.
    Good luck.
      If it is a dell (not sure about how others work probably similar) you should be able to hit function (Fn) then crt/lcd (F8)
      HTH
        try closing the lid...seriously
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          I have the same problem with my Sony PSOne LCD screen. Its connected via a PCI card as secondary display. I have to have it as secondary because the other way I can not use Ati Tray Tools (My primary display is hooked to ATI X1600 pro AGP card).. Hope someone knows the way of getting DVD work on the secondary display..
