9.0" Wide LVDS LCD Panel?
  • 9.0" Wide LVDS LCD Panel?
    In my never ending quest to find a suitable wide aspect LVDS LCD panel, I came across this model from NEC:
    NEC NL8048BC24-01
    9.0" Wide LVDS LCD panel, 800x480, 16 Million colors (vs 262,000)
    400 NIT brightness, 2 CCFL lamps.
    Operating temp -20 to +70 Celsius
    Touch panel available.
    Specs:
    http://www.nec-lcd.com/english/produ...8bc24-01d.html
    A panel such as this would be larger than the standard double-din opening, but according to my measurements, it would fit inside the dash of my WRX STi (I upgraded!) with some heavy bezel re-working.
    The LCD panels are available, so I'm trying to see if I can get it sourced.
    I'm also thinking of making up a circuit board that would allow for easier long-distance (~6 foot) LVDS wiring, using shielded / unshielded RJ45 network cables, using 4 or 5 network cables.
    Would anybody else be interested in a 9.0" Wide LVDS LCD panel?
    why build 4 or 5 cat 5 cables with circut boards? It will be a lot easier to just build a single cable with lvds, inverter, (and usb if wanted). I have built very durable 15 ft. long lvds cables with inverter and usb, and can keep the overall diameter to a size comparable to a good vga cable.
    Cost is more, but when you consider the bulk of running 4 or 5 cat 5 cables, and the fact that cat5 is solid core as apposed to stranded (read flexability) it would seem the cat5 route would not be desireable.
    Just my 2 cents, not trying to pee on your parade.
    Side note:
    I have submitted a rfq to 2 of my lcd distributors for pricing, with and without touch.
    Will advise you via email on this.
      Side note:
      Those are all good ideas, and I'll take them into consideration..
      My thought as to the circuit board route was to make the long run cable connections more of a modular thing as opposed to a single cable with fragile connectors on each end.
      For example, the previous LVDS motherboard I used has a Hirose DF19 connector on the motherboard.. a very small, 40-pin half-pitch sized connector.
      I was able to make my own short LVDS cable, but it was very difficult to solder the contacts onto the wires. They were really meant to be crimped, but a Hirose crimp tool is a few thousand dollars.
      Think you can help me with making the cable assembly?
      Toss me an e-mail, and see if you can get a full spec sheet for the LCD with pinouts and such.
        I'm definitely interested in obtaining one of these panels. Have you had any luck?
          I have a RFQ (Request for Quote) out through some of MotorCity's distributors - it just takes them a week or two to respond.
          The chances are good that we'll be able to get some, though at what cost I don't know.. I'm sure they'll be expensive, at least for the first run.
          I've also succeded in getting Kontron to provide a BIOS change to their 986LCD motherboard to drive the panel. There's a thread in General Hardware on that.
          I should also have a full datasheet on the LCD panel in a few days - I contacted NEC and asked for one.
            I got a response from NEC, which was that they don't send out data sheets directly, but to instead contact one of their resellers for my area.
            So I contacted the local reseller, which has an office a very close 10 miles from my home.
            In fact, I went in to their office this afternoon, and spoke with one of their Field Sales Engineers.
            He said that he has a few "clean room" companies in the area that can get me the LCD panels, and also indicated that they can also do transflective upgrades.
            He also sent me the data sheet on the LCD panel, but I haven't received it yet.. it may have bounced. I'll check again on Monday.
            So the current plans are to purchase:
            • Two of the 9.0" LCD panels - one to go in the radio area of my WRX STi, and the second to go on top where the clock housing is. Also includes associated electronics - inverter, touch controller, etc..
            • The LCD panels will have Capacitive Touch Panels - they react to the minute electrical currents in your fingers, and not to pressure. Very durable, made of glass.
            • The LCD panels MAY be enhanced with Transflective upgrades, depending on the cost.
              Again, awesome work in tracking these down. Transflective? YES. It's sounding like the ultimate panel. Now.... will it fit?
              I'm guessing these will come with no bezel whatsoever? Bare with me - I've only ever purchased retail panels. How are you planning on mounting the screen to your housing? Bottom line, about how much space will I need? Based on my relatively loose estimations, it should barely fit into my dash, but I want to make sure before I drop the huge coin. Be sure to keep your threads updated with progress as I plan to follow your lead.
                Based on the specifications link in the first post, the panel's physical dimensions are 220.5 mm (typ.) x 136.5 mm (typ.) x 11.0 mm (max.) - Width, Height, and Depth/Thickness.
                Based on those dimensions, the panel should fit in two places on my 2005 Subaru Impreza WRX STi - in the dash where the radio is, and on top of the dash in a clock housing.
                I have a thread in Fabrication titled 9.0" Wide LCD in 2005 Subaru Impreza WRX STi that you may want to follow.
                Basically, I'm going to get some dense prototyping foam, carve and machine it to fit inside the recesseses of my dash, and fit the LCD panel to the foam piece.
                Once it fits, I'll make a mold of it and cast it into plastic.
                I'm also making a bezel in much the same way.
                Assuming you have a 2005 or 2004 Impreza with Auto Climate controls, then it should fit, and I'll probably be able to make a kit.
                Otherwise, you'll have to come up with some fabrication of your own if your vehicle is different..
                  Guiliano, sounds a great project, any idea of the price yet?
                  And how is this panel preferable to others? Is it a significant step on in terms of spec, or is the widescreen the main attraction?
                    Nope, no idea on price yet.. If I'm lucky I might have an idea in the next week or two.. or after the holidays.
                    I'm guessing it'll be in the $500 - $750 range, but that's pure speculation right now. The MP3car.com 7" transflective screen is $629, for a comparison.
                    I have the feelers out, so it's only a matter of time.
                    Reasons why this model may be preferable:
                    • A 800x480 widescreen LCD is nearly the same aspect as most double-din openings, making the panels easier to fit in automotive dashes.
                    • An 8" widescreen viewable area is just about the exact size of a double-din.
                    • However, a LVDS-driven 8" widescreen LCD is not generally available on the market. This 9" widescreen model is available on the market.
                    • Higher contrast ratio - 600:1 - better than most that I've seen. The Liliput 8" widescreen model is only 200:1 contrast, for example.
                    • This LVDS panel is a 24-bit panel, meaning it can display 16 Million colors. Most other LCD panels are 18-bit, or 262,000 colors.
                    • Industrial operating temperature range: -20C to +70C
                      Not that most people would operate at -20C, but I'm sure there are those who may want to ensure that the LCD won't be affected by freezing temperatures.
                      Good news!
                      I have received a PDF copy of the specification sheet for the NEC 9.0" LVDS LCD panel (NL8048BC24-01).
                      Out of respect of NEC's copyrights, I won't post the spec sheet here... the security on the PDF is tight enough that I can't even copy text..
                      However, if you need it, e-mail me.
                      Tidbits from the spec sheet:
                      • Display Area: 198.8 mm wide, 118.08 mm tall. 23cm or 9.0" diagonal. This is the viewable area.
                      • Physical size: 220.5 mm Wide, 136.5 mm High, 10.5 mm thick - without a touch panel. Add a few mm for touch..
                      • Resolution: 800 x 480, 0.246 x 0.246 mm pixel pitch.
                      • 16,777,216 Colors at 24-bit, or 262,144 Colors at 18-bit. Most LVDS boards these days can drive 24-bit color.
                      • Weight: 365g
                      • Contrast Ratio: 600:1
                      • Image rotation capabilities built in - right side up, or rotated 180 (upside down).
                      • LCD response time: 25 ms
                      • Backlight is 2 CCFL lamps, user replacable! It appears that the lamps run horizontally across the middle of the display.
                      • 400 NIT brightness without a touch panel.. about 8-10% less with a touch panel. TBD.
                      • The mounting holes for the LCD panel are on the sides, and are very small M4 metric sizes.
                      I've reached a sales contact at the local distributor, and hopefully should be talking with them soon.
                        It looks like it will only be a matter of time (and $$$) now. Have you ironed out plans for a circuit board/cable interface?
                          The cable pin mappings I have mapped out, now that I have the data sheet.. LVDS actually makes it fairly simple.
                          The actual cable I'll probably have MotorCity make for me, somewhere around 10-15' long.
                          Pricing and availability is still somewhat uncertain...
                          I'm waiting to hear from both my local reseller and MotorCity's resellers.
                          But as you said, it's a matter of time, money, and reaching out to the right contacts.
                          Most of these resellers deal with large volume customers, so small orders are somewhat difficult.
                            Alright, I have a confirmed contact for obtaining the LCD panels.
                            I contacted Future Electronics, and they do carry the panel, but they are currently out of stock - they had like 100, and someone else bought all of them.
                            I'll be sending them an e-mail to follow up and get a quote and expected lead time.
                            However, one thing I do know right now is that the re-shipment isn't due until mid March 2007.. I can wait.
                              Someone ordered all 100? That's going to be one wicked car pc.
                              Is Future Electronics able to provide the transflective upgrade and touchscreen overlay or is that sourced through another 3rd party?
