how do i convert a fanuc monitor?
  • how do i convert a fanuc monitor?
    the crt monitor on our wire machine broke. how can i hook up a pc monitor to the machine?
    It depends on what kind of wire machine it is and what model (you didn't provide any info about the equipment). Some just use a standard monitor inside the cabinet while others use LVDS connections to onboard video. You should just be able to open up the cabinet from the back (usually have a key lock) and then pull the monitor out and stick a new one in if it uses standard cables.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
