Excessive?
  • Excessive?
    I picked this LCD up from earthlcd.com. Perhaps 12.1" is a bit much, but I love the onboard VGA and touchscreen controllers. It also turns on and off when a VGA signal is/is not present. What is really great is a high enough resolution that I can still control with a touch screen.
    Regards,
    Todd E. Johnson
    http://www.groomlakelabs.com/grandamp/
    How did you mount that screen? I've got a similar size screen that I want to mount in almost exactly the same place. Do you have some kind of bracket back there or what? Would you mind taking a pic of the back of that so I can see the setup?
    Snak
    Snak
      It is a simple block of wood that fits in my single din stereo chassis. It has a groove in the top for the Power, VGA Cable, and USB cable for the Touchscreen Controller. It is simply covered in generic upholstry from good ole Wal-Mart. The bolts in the bottom align with a hole between the radio and enviremental controls. Large washers and a few nuts are used to anchor the entire unit to the center of the dash. The face plate is a double din to single din conversion for GM vehicles.
      H.T.H.
      Regards,
      Todd E. Johnson
        Now the hard part: How did you get the LCD to stay mounted on that wooden block sticking out of your DIN slot?
        Grand AMplifier Project 1.0:
        http://drive.to/cliffsgrandamgt/
        http://www.astallaslions.com/carmp3/
        -Eden 800 mini-itx motherboard
        -5.6 NTSC TFT-LCD
        -80 gig hard drive
        -128 MB RAM
        -MPBS1 DC-DC PSU
        -PB Remote /w Girder
        -Media Engine & Windows XP
        -Playstation II also added
        -Steering Wheel Buttons modified for Control.
          Using two rather large wood screws and tabs on the back of the LCD housing. I use a spacer (or wedge) between the LCD housing and block of wood. This pic is a bit dark, but it shows the mounting and cables a bit better:
          Regards,
          Todd E. Johnson
