What is this connector?
  • What is this connector?
    Does anyone know what this connector is - not the VGA, the other side, where can I buy a male to female of this connector?? i bought an extension cable, and i need to hook it up to a Lilliput connection.
    anyone?
    Audi A8L
    CENTRAFUSE
    EN15000, 1g DDRII | 200g Media | Bluetooth
    Rear Camera | Dvd | Edge | Nav | Internet | XM
    www.mkippen.com
    Bus mouse cable, also called 9 Pin Mini-Din.
    2002 Acura RSX CarPC Worklog
    Current CarPC Expenses
      if you have that cord, why dont you get a vga extension instead, just seems easier
      my setup - finally
      http://www.mp3car.com/vbulletin/showthread.php?t=50494
        If you extend the vga, it can cause mass ghosting/video lag.
          You sure??? I count 10
            get SVGA cable... i have a run of 16' and im fine. svga is usually alot better for longer runs because it has better shielding and thicker guage wires and ferrite cores built into on both ends. itll cause less problems.
              thanks for the info guys!
              Audi A8L
              CENTRAFUSE
              www.mkippen.com
                The older version of the Lilliput screen uses a 9 pin mini din. But the my screen uses 10 pins.
                I read about the 9 pin an ordered a cable before i got my screen and realized it had 10... yeah that 10th pin must be important cause 9 just didn't do it for me. [why do i want to go bowling now?]
                I have been searching all morning for a pre-made 10 pin mini din cable, now i'm just looking for caps so i can make my own.
                I'll post any info i find.
                  any luck on finding the 10 pin mini din connectors? i have been searching for 3 weeks now with no luck.
