Disappearing display.
  • Disappearing display.
    I cannot recall the model number right now. 7" Xenarc with LED backlighting. A couple years (2-3) since I purchased and installed.
    Suddenly it has taken to showing display for a couple of seconds, the disappear. It won't return until I press the power button turning it off, then on again. Then it will stick around for a couple of seconds and go blank again. If I do this a few times, it might stay on for a while. Power light is still on when the display disappears.
    VGA signal connections are tight.
    Could this be the infamous ribbon cable issue I have read about? Is it time for yet another monitor?
    John
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    is it a power supply issue?
      Are you referring to the external power to the monitor or it's built-in circuits. The external supply is fine.
      03 Cadillac CTS
        Sounds to me like a heat and/or bad soldering issue. Do some testing with some cooling spray (electronics safe) and see if it helps.
        Failure is not an option...
        __________________________________________________ ______________________________
        The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
