Mazda 3 Carputer Idea: Assistance
  • Mazda 3 Carputer Idea: Assistance
    Hello everyone.
    I am hoping that this is enough information to be offered assistance. I recently bought a 2005 Mazda 3 S Touring and the main mod i have in mind is to construct and install a carputer system. I would like the mini-itx computer in the glovebox (which is pretty big btw). The screen would not replace the current system at all. What it will do is be flush above the top vents in the center console as is true with the stock navigation system that comes with the Grand Touring model. Specs are below:
    O/S Install: Windows XP Media Center Edition 2005
    Software: Maybe the StreetDeck Pro Software, otherwise standard software
    Features: Movies, MP3, DVD, Navigation, CD-Audio, and emulation gaming
    Options: Bluetooth (for mouse), GPS (for nav)
    The link to all the parts I am looking into is in this Word document: Click Here
    The diagram showing my interior and placement of units
    Closeup of the end result i'd like to see for the lilliput monitor that manually can flip up:
    The questions I have are the following. Would the on-board video for the Jetway motherboard mentioned in the word document be sufficient to run Media Center application within Windows, or at least StreetDeck at 30fps?
    If not, would a PCI Radeon video card fit and work in the case mentioned? Lastly, after assembling the computer ready to go (OS installed and everything), would it be practical to have a shop install this instead of doing it myself? I'm not very savy when it comes to DC-DC converters and such, little worried about that.
    Thanks for all your help!
    Do you know where to get that piece of the dash??? or is that a custom fab?
      In my experience, onboard audio from the MII12000 was adequate. Nothing fantastic, but it was good for my needs.
      If you're not comfortable learning about the wiring in the car, take it somewhere.
      Jan Bennett
        you can get it from japanparts.com, although i have trouble viewing that web page because it uses japanese language pack.
        Red, thanks for your input. You mean onboard video correct, not audio? I would probably go with the MII12000 and no pci video expansion card to start off, instead of the jetway.
          I have this and a 7 in touchscreen and I am putting in my pc today. It is going to be pretty much the same thing that you are going to do.
          http://cgi.ebay.com/ebaymotors/MAZDA...spagenameZWDVW
            I would recommend the SP13000 from VIA, which is a 1.3GHz. With the PSU, you can find the M2-ATX at a cheaper price. The screen, well, after reading all the remarks from people having trouble with the lilliput, I would go with the Xenarc instead.
            With the case, if you don't need the internal CD, the VoomPC case is a better choice and might be smaller.
            With the mounting of the screen, it really looks like it will need some customization. I like the pod from ebay posted, but I don't like the flip out screen used because it makes it be really high. What I would do is to buy the pod and fab it up to accept the regular screen instead. It will be at least 3-5 inches lower then the flip out screen.
              On my EPIA M10000 the onboard audio is pretty good...but the onboard video sux.
              So I am using a pci video card...and onboard audio.
              current projects
                You can find the jetway cheaper on newegg, and theres a rebate at the moment. Just a heads up. http://www.newegg.com/Product/Produc...82E16813153048
                98' Honda CR-V
                http://www.superbluecrv.com
                *OBDMPG, the RR OBD Plugin*
                  thanks for everyone's input. I am most likely going with a jetway motherboard, thanks for the link mezz.
                  pinga, that was my first choice, but as salvi posted, i would like everything to be embedded into the dash, not sticking out as it will sit too high and attact too much attention from cops and robbers alike. so many choices!
                    dude i must know how you mounted that screen to that piece you got from www.japanparts.com i have the EXACT same thing and i am having the most difficult part of mounting my dynamix 8" screen to that little bar that moves in it.
                    please tell me (if possible also show me with pictures) how you mounted the screen to that and did you make the screen permanent or still able to slide up under the cover
                    you can get that piece and many other mazda parts from www.japanparts.com
                    2006 Mazda 3 S Series
                    2.3L 4cyl Engine
                    Current Build
                    - Commell LV-677 Motherboard
                    - Intel Core 2 Duo T5500 CPU
                    - Dual 512MB PC5300\667MHz RAM
                    - Seagate 80GB SATA HDD
                    - M2-ATX 160W PSU
                    - Dynamix 8" LCD Touchscreen
                    - VoomPC I Mini-ITX Case (Black)
                      Do you have the part number for the housing at japanparts? I can't seem to find it on the website an dam dying to get one.
                        2.3L 4cyl Engine
                        Current Build
                        - M2-ATX 160W PSU
                          Inc,
                          it only does 7" or lower that i am aware of
                            there's got to be a way to get this 8" mounted. who would you suggest taking it to to get it fabricated to mount and fit right?
                            2.3L 4cyl Engine
                            Current Build
                            - M2-ATX 160W PSU
                              Those using the mount from Japanparts, how is the reach to the screen? Also has anyone got the steering wheel buttons operating the computer? I just ripped apart my speed3 today and it's quite an interesting little inside going on there.
                              Just for those who might be curious about running a power line through the firewall, there's a nice place to do it right behind the glove box, which is so simple to get out. Just a piece of trim, 2 screws, and pop it out. But right behind there is the main wire bundle coming in from the engine bay. In there is a rubber grommet that has a small dimple that seems to be made for running a power line. Just poke through that and yank your powerline. Just thought I'd share that little nugget as I spent most of the day finding the best way of running that powerline and couldn't find any help on forums.
