Amp to Subs turns on and off
  • Amp to Subs turns on and off
    i powered my amp up into this new car.. when i put power thru the sub the amp stops sending sound until i lower the volume and then it resumes pushing the sub at the lower volume... anything i can trouble shoot?
    I got nothing. Possibly some type of overload protection on the amp? Does a red led come on the amp when the audio goes out?
    Maybe some more info. Stock Stereo? what kind of amp. How is everythintg wired? Maybe check your ground connection on the amp. sometimes amps will cut out if there is bad ground.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
      probably clipping
        its clipping ... i changed out the amp and it all works fine now .. guessing after 6 years the kenwood finally gave out .. no worries
