How to mount carpc box
  • How to mount carpc box
    I have a microatx CarPC in my trunk and I'm trying to figure out the best way to install it permanently.
    I have dual 12" subs, 2x200 watts in my trunk. I like to turn it up. This won't change. My hard drive just died (Maxtor 3.5 80 gig). It worked fine until (my theory) my pc case got pushed up against my sub box (contents shifted during flight). I have a temporary, smaller 3.5" hard drive in there now so I have tunes, and have made an effort to keep the pc and sub box separated.
    My question is -- is it better to hard-mount the CarPC box to the car (like screwed in) or have it just kinda strapped in? Where is a good place to mount the hard drive? I've seen that some people fabricate a mount under the rear deck -- is that recognized as a location with less vibration? Or should I do the USB enclosure under my seat thing?
    I plan on getting either a laptop hard drive or CF as my boot disk, and then having a larger 3.5" drive for media storage. Any thoughts?
    My personal opinion is to try and get it separated from your subs. Plenty of people have thier PC mounted on or near their subs but hard drives are not made to withstand vibrations. Shocks they handle fairly well, vibrations they dont. I would hard mount it to the car in whatever spot you can that has the least vibration from your subs.
    My Work Thread:
    http://www.mp3car.com/vbulletin/showthread.php?t=72552
    Source switcher for Lill
    http://www.mp3car.com/vbulletin/show...d=1#post841007
      Try using some sound deadner around the case to reduce vibration, but be sure your case is well ventilated cause sound deads are heat proof to.
      Design [000000000-]90%
      Parts [000-------]30%
      Installation[----------]0%
      Integration[000-------]30%
        Make sure you have good air flow and mount the case firmly to the car. Do not worry about the rest.
        TruckinMP3
        Read the FAQ!
          This might be obvious but it needs saying
          I'm a newbie myself, but I do know a bit about computers and sound. This is going to sound really dumb, but here goes.
          Isn't a speaker just a big magnet? I would have thought that, unless you have some kind of shielding you need to keep your hard drive as far away from that magnetic field as possible.
            Okay that sounds reasonable. I'm mostly concerned about whether I should keep the hard drive in the case (in the trunk) or relocate it to the passenger compartment.
              Personally, as long as you can hide it to a certain extent, I'd stick it in the passenger compartment, makes wiring easier for one thing!
                If you think there are enough vibrations to really cause a problem, you could install the HDD in a verticle position which will prevent the platters from hitting. I always had mine vertical, but it was for installion ease. Horizontal should be fine too for most, but verticle will still offer some amount of benefit even though today's drives are much more durable than even a year ago.
                Its not the cards you're dealt, its how you play the hand!
                Originally posted by ryuandwings
                Where can I get a roll of tin foil?
                I been looking for that all over the net, but I can't find it.
                Please help.
                  I think a good place to start would be some duct tape. That way you can a least secure your CarPC long enough for you to look at more permanent options without loosing another Hard drive.
                  Carputer Haiku (thanks Ian Hughes)
                  Serious error.
                  All shortcuts have disappeared.
                  Screen. Mind. Both are blank.
                    As for HD/PC mount, do .
                    If there is space in the cabin, install your PC there. Why? it will share the heat and AC with the occupants.
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
