Radio swap '91 Camry to '93 Camry
  • Radio swap '91 Camry to '93 Camry
    I recently had a '91 toyota camry throw an engine rod and bought a '93 the new one has a bad radio and i was wondering if anyone knows if i can switch them out?
    If this is possible how would i go about it?
    CD,SE,LE,XLE? Sedan/ Wagon? for each vehicle. It may not make a difference, but I'm not going to do all the searching to make sure.
    Lemme know and I'll look it up for you.
    It's been a while...
      the 93 is the LE model and the 91 i dont really know; neither is a wagon
        if the 93 originally had a CD player, that means it also had an external amplifier, which means that the harnesses have different wires...you could still make it work, it will be just a little more difficult. One way to check is to look for a pink wire and violet wire (and maybe a pink/blue one)in the stock harness going to the non-existing radio in the 93.
          how do i remove them from there respective cars though?
            Camry Step By Step, courtesy InstallDr.com
