Newb needing Help
  • Newb needing Help
    Hi im new here but i have been looking around and gathering knowledge for a long time. I have a lot of past expierence with building custom pcs and believe i will be fine building CarPC. But i need some help picking components
    I want to be using the PC for:
    DVD playing (dont need mp3)
    GPS Navigation
    Engine Monitoring and Controlling
    Built-in 802.11 wireless
    I was also hoping to run Windows Vista on it
    I want something with 1gb ddr on it but picking a single motherboard over the others i am finding to be a difficult feat.
    Thanks to all in advance
    Red
    Choosing components is entirely up to you. I suggest loking through worklogs and the SOYP forum and seeing what components others have used.
    The FAQ Emporium is also an invaluable informational resource.
    I would recommend against Windows Vista. There's no need, and it's a big fat chunk of bloatware that you don't need in the car.
    Couple that witht he fact that it's brand new and as a result doesn't support some hardware and software, and you've got reasons to forego Vista, at least for now.
      cheers for the advice
      i guess vista is too buggy i was wondering because it has built in support for touch screens and all that.
        Native support for a touchscreen is only one small piece fo the equation.
          Ive been looking around and there isnt anything equivalent to OBDII for my car
          it is a 1991 MR2 GLimited
          It has an ecu and i can get error codes out of it with the hairpin trick but would it work with a CarPC
            Yeah, but whatever touchscreen you buy is going to be able to supply you the software to support it.
            I did a laptop install, but you might be getting more function with what you want doing it with a PC setup.
            Mike M
            2006 Accord VP Sedan
            My worklog
            http://www.mp3car.com/vbulletin/work...-dads-car.html
              You may be out of luck on the guages engine management. The pre 94/95 is tough and not standard like OBD2. I had a similar system in my 91 RX7. Mazda made a reader for it, but no-one else I found did.
              Mike M
              My worklog
                Don't run Vista unless you will be sticking a DX10 video card in it, and plan on playing Crysis on a 22" monitor from your back seat.
                current projects
                  no back seat
                  i do not have a backseat
                  the carpc is mostly for the passenger to play nintendo roms on.
                  and when needed adjust air intake/fuel intake but it seems i would not be able to do that with my car.
                    You can run nintendo roms on a modified Xbox...and run it through a standard monitor...cheaper too..
                    current projects
                      the coolness in having a carputer is too good though but it isnt worth getting if i cannot find a way to connect my engine to the carpc
                        considing the year, it's questionable.
                        OBD-II came about in the mid-90s. Good luck with it, though.
                        One option might be replacing the motor & electronics from a newer model. That's nnot in everyone's budget, obviously.
                          I think you would be better off going to a forum dedicated to your car and finding out if there is any package that will run on a computer that will read your ECU.
                          Jan Bennett
                            ok all
                            thanks very much for your help
