A few PC Questions
  • A few PC Questions
    Hi all!
    I began developing a CarPC a few months back and it got put on hold for a short time while I came up with the funds to finish it. Now that I have the money, I came up with a few questions concerning some of the things I have planned.
    1) I am planning on getting an M2-ATX power supply for the computer to run on. Dealing with this, is there a way to wire in a 7" touchscreen LCD to the powersupply? Otherwise, how do I make sure the screen turns on and off with the computer/car?
    2) I wanted to get a good GPS system for the computer. What would be the best route to go--a puck or an OEM? I want to make sure it's reliable. Also, what software has been been seen to run the best? I was thinking of iGuidance...
    3) I wanted to have a discrete radar detector. I have read about the Valentine 1 integration into the PC, but would it be better for me to use that or to just take apart a radar detector and mold it into my dash?
    4) Would a computer in my trunk have too long of a cable to power a USB object near my dash/center console?
    5) As far as connecting speakers to the computer, how should I go about doing this? Do I need an amp to relay the signals to all of the speakers from the computer?
    Thanks for any/all help. I'm trying to work out the kinks then start spending away
    To answer question #1, you wire the touchscreen power adapter to the ATX power connector. For the details about this, check out this thread because it's talking about the exact same thing:
    http://www.mp3car.com/vbulletin/powe...ions-help.html
    Using this wiring method will have your touchscreen turn on & off with the computer.
    I don't have any experience with radar detectors or GPS, so I'll let someone more qualified answer that questions for ya.
      1.http://www.mp3car.com/vbulletin/lcd-...d-monitor.html
      2.http://www.mp3car.com/vbulletin/gps/...-part-1-a.html
      4. It could be a bit far but you can use a USB repeater cable. Roughly 4m or less should be ok anything above that you could run into problems.
      5. You will either need to go through an amp or a head unit to power your speakers. Personally I prefer a head unit as you get a good radio with it which really has never been matched yet by computer hardware.
      Visit my site V8 Scimitar
      SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
