car pc boot mounted
  • car pc boot mounted
    Hi guys
    I wonder in its quite easy to mount a car pc in my boot(trunk).
    1 will a 10ft usb cable work?
    2 will a 10ft vga cable work?
    3 will remote power switch and reset switch work over 10ft of cable?
    1. Yes, I do that now.
    2. Yes, I do that now, but some people will say you're pushing the limits of VGA. Though I use 15ft and it still works.
    3. I tried, but failed to do that. I haven't had the time to trouble-shoot, but I think it should be possible.
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
      Yep all 3 of your cable runs will work. It may be a good idea to run the VGA far away from the power cables (just so you don't get interference. Also you will need a power wire run to the trunk, but ground the computer in the trunk somewhere (long ground wires aren't a good idea). Good luck!
      91 Acura Integra RS Hatch
      95 Honda Accord LX Sedan (daily driver)
        Well the passat b6 and earlier passats have a 12v output in the boot (trunk) so I don't have to run power
        My concern is the power on and reset from my proposed hu, I don't know what power they will be and I know power degrades over distance
