need some opinions
  • need some opinions
    Building my first carputer, and i have done alot of reading since i have joined this forum. I am very torn to witch direction i want to go.....what i mean is, should i build a pc with regular parts or should i get the mini MB? I know the mini's take less power but what about expandability? I want to install a SB X-FI sound card and some extra USB ports via PCI, but i cant do that with a mini MB can i? Some have one PC-i slot but i would like the option of being able to expand. Also cases are much easier to come by for regular systems.
    Whats everyones 2 cents on this? Thanks In advance
    cheers
    mini-ITX is the way to go IMHO.
    Not only less power needed, but generally less heat needed as well.
    You have to consider being able to power a larger board with the avaliable PSUs.
    Why are you bent on the X-FI card? There are other cards out there that are just as good if not better...even in USB.
    Regarding the USB PCI card...use a powered hub....simple.
    Your comment about cases has be slightly worried...are you just planning on sitting a tower in your trunk?
    There are cases out there (Opus) that have 2 PCI slots anyways and include the 2 PCI slot riser card (1 PCI slot -> 2 PCI slots).
    Jan Bennett
      no i wouldnt dare put a tower in my car LOL i would love to hide it away thats why im going to do the mini ITX but im interested in seeing this riser card....is the case expensive do you know? thanks
        the store here has the case. check there for pricing. there are two cases that might meet your needs.
        Jan Bennett
