P/S M2 question
  • P/S M2 question
    Power supply question.
    I was looking at getting a VOOMPC with a m2 power supply for my final car pc project.
    Now my question is regarding power supply.
    I plan on using a relay in the dash using, radio constant (yellow) and radio switched as a relay signal (red) which will be hardwired to the power adaptor included with a lilput. That will turn on/off monitor as I want.
    Now in running the radio remote wire to trunk were it will activate/deactivate carpc.
    Up in the dash I plan on having a dvd slim drive, I will use a slim-IDE- USB2.0 interface, now this is were the first question comes. Can I grab the +5volts right from the P/S to power the drive?
    Second question is, I will want to power an SB audigee, which is also needs +5 volts, will I have enough reserve on the M2 to power that as well?
    As for USB devices I plan to run
    Touch screen
    Sound Blaster
    IDE-USB
    GPS rec
    Bluetooth dongle
    Wi-fi
    USB outlet up in the dash
    RF keyboard/mouse combo
    Now clearly I will need a HUB, I refuse to “hot-swap” anything. I do not require an externally powered hub do I? if so, is there any +5v add-ons to the m2 like there are for the carnetix 1900?
    Mobile Dynamics, *B.S.E Honors, Working On B.S.M.E* Audio Engineering Society Member, LKKR Kickboxing 3X Gold Medalist, IDSF Competitive Dance, Can-Fit Pro Personal Trainer Certified.
