Whats the cheapest in car pc?
  • Whats the cheapest in car pc?
    Hi im new to this and just done a bit of reading and searching and just want some friendly help from you guys. Whats the cheapest machine thats available for a first in car pc. Dont want it do much apart from Music possible DVD and GPS. All the prices in the shop are in $ can they be shipped to the UK? Thanks
    Matt
    just buy an old something off ebay. For music and basic CarPC anything, a P3 750Mhz and up will work.
    1.9in x 2.9in -- 47mm x 73mm
      I cant seem to find anything on there been looking but its all like £300-400
        Well you havent looked very hard...
        http://cgi.ebay.co.uk/Compaq-Deskpro...QQcmdZViewItem
        http://cgi.ebay.co.uk/Intel-P4-Deskt...QQcmdZViewItem
        http://cgi.ebay.co.uk/DELL-GX270-SFF...QQcmdZViewItem
        With 20 seconds.
        I am sure you can find something for cheap. It may take a few days too. Also check out http://linitx.com/ because they are stationed in the EU and VAT is calculated too.
        EDIT: Just so you know, there are 3 things everyone wants in a CarPC: Low Cost, High Power, Small Size. Well Pick 2. Because that is all you get. You want low cost. So that is one. So now your options are A) Low Cost and High Power, or B) Low Cost and Small Size. Meaning if you choose A then you get a full ATX board and your DC-DC PSU will need to be expensve to power it or an inverter. If you use option B then you can use mini-itx but probably with an embedded 800mhz via processor, but your DC-DC solution will be cheap. See how it works?
          Was kind of looking for something a little smaller thats probably why. Havent got much room in boot so would really be looking to place ideally behind dash. Will just keep on looking if not may just buy a case and ask the dad to put one together. Cheers
            Just wanted something small and relatively cheap. Think ill be asking the dad to quote me on building one. cheers
              Ok, small and cheap means slow. People do it, but it is going to be slow.
              If the above is too expensive, what is your price range? Thats only $30GBP! Brely anything. Your screen alone will be $200USD at a minimum.
                Cheap? my first one was $120 including power and screen...see avitar.
                It all depends on what you want...are willing to pay for.
                current projects
