Completely New to this!!!
  • Completely New to this!!!
    Originally posted by Maskell View Post
    I am wondering if i can hook up the computer to the main ecu and get live data from the engine.
    Yes you can.
    Also my other concern is how can i get a good quality of sound with it?
    Yes you can.
    I would be hoping to build a boot install and run a few amps for mid and hi along with an amp to run 2 Subs! I have searched and seaerched for information on this but havent had any luck! Any help or advice would be really highly appreciated.
    Here's a good starting point: http://www.mp3car.com/vbulletin/advfaq.php
    I must add that i have heard of the Ibus aswell, but again am not sure what this can be used to do except monitor and control displays and lights.
    Thanks in advance!
    Lots of information about IBUS on these forums. I suggest searching for IBUS and seeing what you can dig up.
    Welcome to the madness!
    How about the Wiki?
      I thought the ibus was bimmer only?
      1.9in x 2.9in -- 47mm x 73mm
        Yeah....
        I am hoping to build a computer for my newly acquired BMW E46 330Ci Sport.
        How about the Wiki?
          Originally posted by DarquePervert View Post
          Yeah....
          I missed that. I looked at the Vehicle on the side.
          Vehicle: Vauxhall Astra G SRi-T
          Ah well. anyways!
            It's called OBD-II support. I'd head over to the OBD-II forum here on mp3car.com and see what all there is out there.
            If you can't then you're not qualified to be installing... It's not hard to do and if you want to go nuts with sound quality, there's a few of us here that can help on that too.
            Searched for what exactly?
            btw!
            Jan Bennett
                what's the problem with running all of your components as well as your subs? I don't see anything abnormal about that?
                Control what from the screen? Are you wanting to do all audio tuning via the screen? if so, there's a LOT of discussion about this very topic in the car audio forum here.
                If you don't know much about computer components I suggest you start reading and researching. There's a ton of information to be had on these forums to help newbies like yourself.
                Jan Bennett
                      No need to cancel.
                      We'll still be here if you need/want.
                      What the heck is "the UK way" anyway? Are you cavorting with the folks at Digital-Car or something?
                      How about the Wiki?
                          Certainly not, just all u guys seem to do it yourself! The UK way we cheat! Sorry if i offended anyone there. Should of ellaborated on it.
                          lmao!
                          I love it!
                          Well if you have the cash, then do as you wish. That is what the G4 is used as anyways, so you are part of a growing subsector of CarPCs.
                          If you have problems after the install, or rather when you have problems, just post back here and we will still help.
                          Also we would still be insterested in pictures probably if the install is done correctly.
                              It's a PC....even your desktop has issues...
                              Jan Bennett
