M2-ATX Car PC 160W connector wires
This topic is closed.
  • M2-ATX Car PC 160W connector wires
    Hi,
    I lost the manuals and CD's for my car computer. I'm new to this and I'm in the process of installing my first car computer.
    My question is on the M2-ATX power supply. I'm looking to identify the wires into the power supply from the car. I've worked out the constan live, ground and IGN wires, but there are a few more that I'm not sure about. I know one of them must be my remote connection to an AMP. I searched google and only found a manual for the actual power supply whcih maps the actual board. I've physically put the computer into the car (unwired), and I'm trying to avoid pulling it out. If I have to so be it...... Any suggestions help, would be welcome. I've attached a diagram
    [IMG]c:\data\temp\wiring.jpg[/IMG]
    Things to do
    • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
    Find an installation manual for an aftermarket radio harness for your car.
    They could identify the wires that connect from your car.
      For this I need to know what case you are using. When looking at the connector I guess it is an Ampie/Voom case. If it is you can take a look here.
      BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
      Bezel Worklog-My Install -iDrive F01 RR Skin
        Thanks Bimmerstyle,
        I'm using a Voom Case and that link has exactly what I'm looking for.
        Things to do
