Newbie Head unit question
  • Newbie Head unit question
    Is it possible to fit 2 head units, single din size, into a double din unit, this sounds stupid i know but i've searched the FAQs and other posts and can't find a solid answer and i just want reassurance before i start buying components as this is being my last thing to figure out before i start purchasing my carpc
    Planned ... 95%
    Purchased 25%
    Installed ... 0%
    WorkLog
    sort yes sorta no.... i would be concerned with the face of either unit being too large and intsll kits that "flare" the single din opening for a larger fit on one making the other smaller
    but i know for my car the cobalt they make a double din kit that has 2 single din openings
    J. J
    http://www.cardomain.com/ride/2604492
    TYPE RF System INSTALLED:
    RAVDVD1, Front: Silk FNX/FNQ 6.5, Highs amp: 801X
    Working on:
    Midbass: 8 HX2, Center: 4 FNQ, Midbass Amp: 801s, Center Amp: 301m, Sub Amp: T30001bd, Processors: 2 3Sixty.2
      single-DIN is 7" x 2"... double-DIN is 7" x 4"
      the short answer is YES, you can fit 2 single-DIN headunits into a double-DIN opening. but many headunits use an outter "frame" to that surrounds the faceplate and covers the instal sleeve. this "frame" is slightly larger than a single-DIN opening. you can work around that issue by modifying the existing frame(s) or making your own.
      have fun
      F150 Truckputer [1.0] (coming soon!)
      Fusion Carputer [2.0]
      Fusion Carputer [1.0]
        thats a much better way to expalin it... props to cg
        J. J
        Working on:
          Has anybody ever made their own/modded one? if so how difficult would it be. I'm hoping to mount a head unit, and in dash motorized screen.
          Planned ... 95%
          Purchased 25%
          Installed ... 0%
          WorkLog
            Made their own what?
            Headunit?
            Double-DIN bezel?
            How about the Wiki?
              the frames that surround the units.
              Planned ... 95%
              Purchased 25%
              Installed ... 0%
              WorkLog
                check to see if they make a dobule din that has 2 single din openings... or just buy a double din. modding a single din is going to be a *****
                J. J
                Working on:
                  http://cgi.ebay.com/Chevy-Malibu-01-...QQcmdZViewItem
                  bamb made for 2 single din openings
                  J. J
                  Working on:
                    whoops urs is an 04
                    http://cgi.ebay.com/Chevy-Malibu-04-...QQcmdZViewItem
                    J. J
                    Working on:
                      mine is an 04, but is actually the same body style as the 03s.
                      Planned ... 95%
                      Purchased 25%
                      Installed ... 0%
                      WorkLog
                        The first link is exactly what i need, Thanks a ton man i actually just purchased it, i guess now i really do have to install a carpc since i've started buying stuff now...
                        Planned ... 95%
                        Purchased 25%
                        Installed ... 0%
                        WorkLog
                          the second link is the same thing but ur year
                          J. J
                          Working on:
