My Car Pc Project
  • My Car Pc Project
    Hi, i have just bought this off ebay...
    Item number: 110232685337
    i would like it hard-wired into my car, i would like it to turn on with my ignition and shut down when i turn the ignition off. what cables etc. would i need to buy in order to do this?
    also, at the moment it has media engine front end installed, i would like to use centrafuse, but i would like to know how i can use the current satnav and phone bluetooth setup in conjunction with centrafuse?
    sorry for all the questions. also would a GPS reciever work if it was on the parcel shelf? or does it have to go in the windscreen?
    i will keep this thread updated with my progress over the next few weeks, here are some pics of the car it is going in. (A VW Lupo GTI)
    Unphased A New and upcoming site for VW owners.
    nice lupo gti
    I think i watched to much night rider
      thanks, any help appreciated though lol
        Read Here First
        Leonardo Da Vinci
          read here second
          Planned ... 95%
          Purchased 25%
          Installed ... 0%
          WorkLog
            how do i know how much power my pc draws and also, where can i buy a power supply, shutdown controller etc. all in one?
            would this do the job?
            Item number: 130207335981 on ebay
              There's a section with links to power calculators in this FAQ: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=2
              http://store.mp3car.com/
              If your PC hardware draws less than the max output of the M2ATX, yes.
              How about the Wiki?
                this is what i end up with, is that right?
                  Pretty low end/low power system there. BUt just fine for in car use for gps and MP3's.
                  Just google for the power requirements of you suystem components, add them up and there you are.
                  It sounds as if it already has a dc-dc ps buy the sounds of this:
                  Now comes with the adapter to run in your home, so you can set it all up how you like it before you move it into your car.
                  And:
                  "Adapter to run from car battery completely stable"
                  "All you do is simply connect it to your car power and plug it in, and away you go. You can hardwire the adapter into your cars electrical system so that the PC is there ready to turn on simply at the push of its button."
                  Contact the seller and they can probably provide the info you need.
                  You did see this:
                  Please note, the software is for you to evaluate only.
                  Right?
                  You may be looking for a new fe soon if it's trial stuff...
                  Leonardo Da Vinci
                    yeah i'm looking at centrafuse at the moment. think thats the one i'm gonna go with but its pretty expensive
                      well, from looking at the back of the unit, I'd say you don't have:
                      1. AGP graphics
                      2. PCI sound card
                      3. DVD drive
                      Cheers
                      Leonardo Da Vinci
                        i'm using a USB dvd drive, mounted in the dash below the monitor. so thats not a problem
                        i was just gonna run a 3.5mm headphone to phono cable straight to my amplifier. will this not work?
                        also, what is AGP graphics?
                          You have it checked in the calculator.......
                          AGP = Accelerated Graphics Port
                          Wiki
                          cheers
                          Leonardo Da Vinci
                            ah, i thought all pc's came with a video card otherwise it wouldnt display anything?
                            am i just being stupid?
                              1st question - Nope.
                              2nd question - Nope.
                              The MB usually has integrated video and sound.
                              Looks like that's what you unit is using.........
                              Don't worry though, that's usually perfectly fine for most car pc's. You may have trouble getting it to display 800x480 depending on the chipset.
                              800x480 is the native resolution of most 7" monitors by the way. If it won't display 800x480 and you don't mind a little scalling of the image, just use 800x600 and be happy.
                              Cheers
                              Leonardo Da Vinci
