Proposal for first CarPC - Opinions and suggestions wanted
  • Proposal for first CarPC - Opinions and suggestions wanted
    I've been lurking for a while now, and am in the process of designing my first CarPC. I have a list of parts, and would like opinions from other people on the system.
    I am looking to have the system do GPS navigation, AM/FM/XM radio, FLAC/MP3 playback, play DVDs and stored movies, and do some low to moderate-end gaming. For all those curious, I don't plan to play games while driving. I do a fair number of road trips, commonly with at least one other passenger, so that aspect would be more for their convenience rather than mine.
    In the future, I would like the system to interface with my car via OBD-II and process video from a dash-cam.
    With that, here are my proposed components:
    CPU: Intel Core 2 Duo E7200 http://www.newegg.com/Product/Produc...82E16819115052
    Motherboard: Gigabyte GA-G31M-S2L http://www.newegg.com/Product/Produc...82E16813128078
    GPU: Jaton 8400GS http://www.newegg.com/Product/Produc...82E16814139018
    RAM: 2GB DDR2-800
    LCD: Lilliput 7" Touchscreen http://store.mp3car.com/2008_Lillipu..._p/mon-016.htm
    PSU: Opus 320W http://store.mp3car.com/OPUS_320W_In..._p/pwr-024.htm
    GPS: BU-353 http://store.mp3car.com/BU_353_Weath..._p/gps-002.htm
    DVD drive: something
    AM/FM radio: something
    XM radio: something
    OS will be Windows XP, front end most likely RR, GPS software IG4.
    Now I know this is an absurd amount of power to put in a car. Here are my thoughts on that:
    I want the system to be capable for future expansion and capabilities, and also want to be able to multi-task (i.e. GPS running in background while dash-cam is running and DVD is playing). Furthermore, all the components have been selected because of their low power aspects. Running it through a few power calculators, I've obtained estimates of 200-225 watts power consumption, which I think it reasonable to overkill. Nevertheless, I decided on the OPUS 320W to have extra headroom as well as for it's startup/shutdown capabilities.
    The micro-ATX motherboard is fairly large, but smaller than others at 9.6x7.6 inches. I plan to put the computer in my dash. The screen will replace the current radio, as that spot is low on the dash, hidden from the sun and very visible for the driver and passengers. The motherboard and power supply will be behind the screen. There is an opening of ~10.5x9 inches behind there, as I moved a few relays and harnesses out of the way.
    As for cooling, the area that I plan to put the motherboard and power supply have air ducts below, to the side, and above, as well as openings to the passenger compartment. For the time being I will just have fans, but if cooling proves to be a problem, some of those air ducts may be modified to produce more moving air.
    For power, there is an empty distribution block just to the left of the driver's feet, with openings already connected to the battery which I will be utilizing.
    FYI, the car is a 98 Chrysler Sebring LXI (coupe), similar to the second-generation Eclipse.
    Thoughts?
    Thanks in advance!
    TTT, interested in opinions on this set-up as well.
      I actually built it soon after posting it, and have been using it in my car for a few months now. So far I've really enjoyed it. For the most part, the system is wildly over-powered, but I knew that going into it. I don't know the exact power draw from the system, but I may hook my multimeter up and get a current draw soon to get an actual idea of how much power the system is pulling. I'm guessing total draw is around 150 watts.
        That's awesome man, quck question: why did you go with the different video card? Does the intel GMA 3100 not work well with the 7" display? I keep reading all these issues with getting a native 800x480 display. I'm definitely a newbie to all this, so I've been reading as much as I can and any experienced information is definitely useful.
          I went with the discrete graphics card for two reasons. First, I wanted to be able to do 3D rendering well (games, etc) mainly for passengers in the car, but also for times when I'm stopped waiting to pick someone up, etc, and not bog down the CPU. Second, I didn't want to have to mess with getting 800x480 to work.
          Unfortunately, I have even more problems now in regard to 800x480. I believe the GMA3100 can be made to work with 800x480. However, PowerStrip doesn't support 8-series Nvidia cards, and the custom resolution feature in the Nvidia drivers apparently has been broken for years, so I'm stuck at 800x600 until Nvidia finally gets its act together with their drivers.
          I was debating buying a 7-series card, or just using the onboard, but right now the 800x600 actually doesn't look that bad, and I'm banking on the idea that Nvidia will support custom resolutions in their drivers soon.
            I see... well hopefully in the near future they will figure things out. As far as power, you said you feel it is only drawing around 150W? Is this with everything you listed above sucessfully running or less? How about the sound quality, and how fast is it on a cold start? Sorry about all the questions, i'm just excited I found someone with the same set-up I was looking to develop.
              No worries about the questions, that's how I got my start too.
              Right now I'm powering the CPU, motherboard, GPU, 2GB RAM, 500GB HDD, LCD, GPS receiver, DVD drive, USB hub, USB mini-keyboard, and USB 802.11G wi-fi device.
              I don't have too much free time right now, but if you're ok with waiting a few days, I can get an actual current measurement from the system to have a concrete power draw number.
              The OPUS 320 watt PSU I'm using said to run a fan over it if pulling above 150 watts. I don't have a fan on it, and it's located away from the CPU and GPU fans, so there is no dedicated cooling for it. It obviously has run for the ~3 months I've had it in the car just fine, including two periods of 9+ hour continuous use when I was on a road trip of 700 miles each way. Also, during the summer months my car would get quite toasty, easily over 100 degrees F at times, and I never had a single lockup or thermal shutdown.
                Yeah, Im in no hurry. I just stumbled across your post and it was very similar to the idea I had as well as the components I have at hand. Thanks for the help you already given me, I'll keep reading and asking questions around the forum to get a better jist of the whole carPC revolution. If you have a spare moment let me know the wattage the system is using.
                In retrospec if you would change one thing about your system, what would it be?
                  My install is similar to yours if not even more over kill. i have 4 screens, a Kino-690S1 with AMD 1.8 ghz Turion X2 processor, 4 large fans and 2 small fans, XM, HD, and some other stuff, all being powered off a OPUS 320 and I never have to put a fan to it. What I would do is have a fan pull air away from it, but dont have it blow on it. Here is a pic of my setup without the case. Towards the back you can see the OPUS and 2 fans which pull air out. The OPUS doesnt even get warm.
                  1X Ainol Novo Flame Tab
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1X 7 inch motorized Screen
                  1x Win 7 PC
                    Wow! That's a big pc. I read that your reasoning was multitasking. How does that perform for you?
                    I am concidering a similar system based on an AMD single core processor. I am mainly interested in quick boot and shutdowns. However, I do run RR and streets and trips 2008 at the same time.
                    What is your boot time? And in your opinion, what factors are more inportant in respect to boot times:What would be the order of determining factors for boot speeds? processor speed/ # cores, RAM/ total amount or using multiple sticks to take advantage of dual channel support, HD speed, or OS/ OS optimization?
                    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
                      Before this was on my back seat, LMAO, you can see why i moved it to this new home. Me, I have always prefered AMD, so when I found the KINO-690S1, I was very happy. Now as a rule the more devices and RAM you have the longer the boot time. I have over 13 USB devices so my post takes about 4 seconds, then about 8 to go to Windows. Without everything connected I boot at about 5 to 6 seconds. Shut down isnt 2 long id say about 6 seconds also, if I had less RAM it would be faster. When coming out of resume/hibernation the PC is very fast about 6 seconds for that. So basically my system suffers a long time from cold boots, which I rarely have to do anyways. Currently I have DDR2 667mhz and I honestly dont know if there is a diffrence since its the RAM I have always used. My hard drive is a 7200 RPM Toshiba Sata drive, is way more responsive then the older 5900 RPM toshiba IDE drive I had before. I have so many devices I was scared to optimize Windows completely, I stripped all language packs out of it, intergrated SP3 with it (my system would not run without SP3) and took out other stuff. In total the install disk was 330MB. I used nLite, which is awsome. I hope I got most of your questions.
                      So to recap: The more RAM the longer hibernation takes. The more devices you have, the longer the post and boot time.
                      PS: This system is awsome when multitasking, My backseat people can be doing thier thing, and I can be doing mine with no hic ups. This includes them playing 3D games, etc.
                      4X MK808b
                      3x Perixx Touchpads
                      3x 7 inch Screens
                      1x Win 7 PC
                        Here is what I had in mind:
                        1:JetWay JM26GT3-SVP Micro ATX AMD Motherboard
                        2:AMD LE-1660 2.8GHz AM2 45W Single-Core Processor
                        3:Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
                        4:Western Digital Caviar SE WD800AAJS 80GB 7200 RPM SATA 3.0Gb/s Hard Drive
                        Looking at your system, I shouldn't have any power issues. I am still undecided on the power Supplies with integrated Startup/Shutdown Controllers. Also, Im debating the Ram. The MB has dual channel support, so I think it would be better to have two sticks. If I go too big, the boot time will decrease. And I don't know yet if the bios has the quick boot option. Wait and see I guess...
                        Oh, and I love your budget %. True, true, true.
                          All though it is a nice price, I would stay away from JetWay, I was reading the reviews and most are bad, alot say its DOA. Since you are using a Micro ATX board, and I know you want it for power, I would get the OPUS 320, that way you wont have to worry about maxing it out, and you could also power the screen and other devices from it. Its pricey, but its also the best you can buy and their customer support is great. Buy directly from them to get a good price. My MoBo has the quick boot enabled, I can only image it would take really long to boot then for me..
                          HAHAHAHAHA, I dont love my budget... I only wanted to spend 1,400.00. You can see that was blown out of the water because of my obsession with being power hungry. If I could go back in time I would shop wiser and cheaper, lol.
                          http://www.newegg.com/Product/Produc...82E16813186151 Here is a board I found, it has good reviews even though only 2 people left them. The stuff this thing has are nice.
                          4X MK808b
                          3x Perixx Touchpads
                          3x 7 inch Screens
                          1x Win 7 PC
