CarPC with factory amp?
  • CarPC with factory amp?
    Alright, I have been searching around but I can't seem to find out how to hook the PC up to my factory amp when I take out the head unit. It is a new Civic Si with a factory sub. I am trying to get away without buying a new amp since there is only 1k miles on it.
    It should be similar to a normal amp and have a remote lead from the head unit to the factory amp. Once you find that lead you use a software called AMP_CTRL or VOLUME_AMP_CTRL. I then bought a device called a PAC TR-4. Its a small device that sends a amplified signal to the remote lead to ensure it turns on.... You then connect the other end of this device to pin #4 on your serial port. 2 other wires also come out of the TR-4, one goes to Ground and the other to a 12V source. Everytime you turn on the car, the TR-4 will wait for a signal from the serial port then turn on once the Amp_CTRL turns on pin #4 on the serial port.
    Have you tried locating the AMP and looking at it? It should say what is what. The connections should be 12V+, Ground, RMT (Remote wire), and audio ports. Once you locate the lead wire (RMT) just find that same wire were the head unit is.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
      i have a 2008 civic SI and i used the factory amp... give me a bit and ill get some information for you (im at work currently)
        Ok First thing... buy yourself a wireharness... trust me.. its better to spend 10 dollars then to have to cut your stock wiring...
        with that said. i purchased my harness at local audio store so im sure you might be able to do the same.
        if not look online
        after that there is 1 wire you will have to cut, because on the back of our radio we have two harness's
        we have 1 small plug and 1 large plug. you need the harness for the large plug because that is where all your audio wires are..
        however, the small plug has your AMP_REMOTE (light blue) wire on it.
        i connected this to the ignition wire off the large plug, so now whenever my car turns on AMP turns on...
        i also have my PC connected to this with a switch in the middle.
        but once you get the harness, it should tell you what wires are what speaker, hook up to RCA then get a Y adaptor to 1/8 plugs and plug into PC.
        if you need more help from there PM me ill gladly help with what i can!
        thanks!
        also check out www.8thcivic.com my name is ohiocivicracer on there they have a lot of great information!
        edit:
        pulled from 8thcivic.com
        :Radio Harness
        +12V DC Constant White
        Switchedd Accessory Violet
        Ground Black
        Power Antenna Gray
        Remote Turn On Light Blue
        Illumintation Red/Black or Gray
        Left Front + Light Green
        Left Front - Pink
        Right Front + Gray
        Right Front - Brown
        Left Rear + Yellow
        Left Rear - Brown
        Right Rear + Blue
        Right Rear - Orange
        :Amplifier Outputs
        Left Front Mid + Light Green
        Left Front Mid - Pink
        Right Front Mid + Gray
        Right Front Mid - Brown
        Left Rear Mid + Yellow
        Left Rear Mid - Brown
        Right Rear Mid + Blue
        Right Rear Mid - Orange
        Subwoofer 1 + Green
        Subwoofer 1 - Red
        :At Speakers
        Left Front Tweeter + Red
        Left Front Tweeter - Green
        Right Front Tweeter + Pink
        Right Front Tweeter - Blue
