'08 Mitsubishi Lancer project
  • '08 Mitsubishi Lancer project
    Hello,
    I've been reading this site for 2 years now,and i'm finally starting my own project.
    1st thing is the power supply... Would this be enough
    http://store.mp3car.com/M2_ATX_160W_..._p/pwr-015.htm
    to power : Abit NF7-S motherboard
    AMD athlon 2400+
    512 MB DDR (400 MHz)
    40 GB WD HDD
    Geforce4 4200ti
    and a DVD drive ?
    Cheers , looking forward for a quick response
    You need to research the power draw of each component you are going to be running off the M2 to be sure that they are not going to need more than 160W at any given point in time. Keep in mind that you can never have too much power from your power supply in that 160W is the maximum wattage that the M2 can deliver at any point in time, if you need only 100W than you will have the same electrical draw with the M2 as you would with the M4.
    The DVD drive is what really makes it tough. When it is not running the draw on your M2 will be significantly lower, however, when it is on. You just want to make sure that you can run everything all at once just incase it happens.
    If I were to guess I would think that would be enough, but you should do the reasearch to be sure.
      How about getting a powered USB hub and letting the USB DVD drive draw from that for power?
