Acer mini-pc as carputer?
  • Acer mini-pc as carputer?
    hello all. i am shoeb from bangladesh, and i drive a JDM 95 Corolla. i recently got interested in carputer, and after reading the car computer 101 here, i think i can try to install one in my car. so i think an Acer L100 or the Acer Veriton L460 mini pc could come in handy.
    any suggestion/opinion/advice would be most welcome. thanks!!
    IT would work. It's very likely that you can use a DC-DC power supply like a Carnetix unit to power it, too.
    However, I have read about a number of problems with overheating of the L100 unit. Because of that, it might not be the ideal choice for use in the car.
    How about the Wiki?
      Alot of Acers laptops seem to have heat issues. i have had a number of people bring me thier acers saying it running slow and they think they have viruses. All of them turned out to have $h!tty heat sinks. If you do intend to use the acer, i would buy a really good docking station that has cooling fans built in.
      1X Ainol Novo Flame Tab
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1X 7 inch motorized Screen
      1x Win 7 PC
        @ darque:
        thanks for the advice. so if i can take care of the ventilation/heating issue, everything else would be okay... right?
        @ hijack:
        that is somewhat true... but the L100 is a mini-desktop, not a notebook. it has two rather slow-moving fans for ventilation... and i plan to take care of the heating/ventilation. so i don't think it would be much of a problem.
        thanks again for the advice!!
          Originally posted by dmc_rider View Post
          @ darque:
          @ hijack:
          Well then that makes it easier.... if you have heat issues, then simply disconnect the fans from the MoBo connectors (most are set at diffrent speeds by the MoBo) and connect directly to the 12V rail so that they are always at full speed. The processor fan on my IEI KINO-690S1 was like that and the PC ran hotter then I liked. I rewired the fan to the 12V rail and have never had heat issues again.
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1x Win 7 PC
            yeah, i wanted to do exactly that and more... got a couple of old chasis cooling fans lying around... so i want to make a dedicated heat vent for the PC with a fan and some tubing.
            can anyone advise me on the screen? must be touchscreen- i dont want to use kbd/mouse... just the screen. which one will be the best?
              If you want the best, it's going to be pricey.
              The Lilliput transflective screen available in the mp3car.com store is generally regarded as "best" because it can be read in direct sunlight and is very bright.
              However, there are also quality screens that are nowhere near as mych. The two major brands are Xenarc and Lilliput. Take your pick, as they both have pros and cons.
              How about the Wiki?
                Every model has a diffrent look and feel and all depends on the user prefrenence. I really didnt want to go with a pricey transflective because I simply didnt need it. The tint on my car does a good job of allowing me to see the screen even in sunlight. I went with the Lilliput EBY-701 because of its price and because it looks like something Dodge would have put in its trucks (the unit isnt going to be molded into my dash, but instead look like a pull out head unit so it looks OEM).
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1x Win 7 PC
