installing software without dvd drive
  • installing software without dvd drive
    okay so i managed to break my dvd drive while doing my car install and i havent bought another one, but i want to install ms streets and trips 07 so i have gps in my car, is there a way to put it on a flash drive so i can install it from there?
    Yep, just copy the entire contents of the disc to a folder in your flash drive, then run the setup.
    Christmas Car Project 2008
    ArrowDash Skin Worklog
      yea i tried to do that but there was an error, maybe the flash drive i used wasnt big enough? I will try again tomorrow.
        ls1bandit,
        You could place the cd-rom in another machine and enable file sharing on the cd-rom device and install it via your local area network connection. You could use an ISO image utility such as UltraISO to create an image of the disc. You could then copy the ISO file to your machine via usb, network, etc. You then mount the image with a utility such as Daemon Tools or VirtualCDRom.
        GarGoil
        VIA Epia M10000 MB
        512 DDR RAM
        40G 2.5 HDD
        M2-ATX
        SP7 7" VGA TS dash
        Lilliput 7" RCA rear
        Holux GM-210 GPS
        Linksys WUSB54G
        Mini-Key USB KB
        CarPCSub 0.71 Win32 + 0.71L Linux
        GPS to Subtitles Recorder
        http://carpcsub.sourceforge.net
