Touchscreen help!
  • Touchscreen help!
    Hey ppl,
    My touchscreen seems to be playing up. When i press the screen the mouse seems to fight to stay on the left hand side :S When i hold the screen the mouse trys to get to my finger but something is wrong here!
    any ideas?
    ian
    if i tap the screen the cursor seems to go far to the left of where i tapped (although up/down is that same) and if i hold the cursor travels from the left to the right of the screen then flicks back to the left and stays there :S
      no idea if this will help but, might want to try it, it seems easy enough.
        This condition is usual indicative that something is touching the touch panel. Generally either the case or mount that you have it in.
          sorted it! seemed to be a driver issue? thanks anyway!
            it's broken again! works fine left to right in the first fifth of the screen the others i have to push really hard to get to flick the mouse over too! going to take apart and check now!
              anyone help please
                OK! it fixed (somehow), i rebooted (both PC and screen) and now its broken again!
                  Try a different version of the touchkit drivers.
                    seems to work again now :S lol
                      You may want to reboot a few times before you celebrate.
                        have done now, still seems ok, also now tried on my desktop pc and the in car pc
                          seems to have gone wrong again! in the same way. Afte many boots its just reverted!
                          The only thing that had changed was that i plugged in my TOMTOM to charge from the pc (via USB), then turned the pc on and the touchscreen was doing its old problems^^.
                          Don't know if this is coincidence or not but any ideas people!
                          thanks
                            anyone else had this problem? thanks!
                              I think the drivers are merely a coincidense. There is something on your screen pressing against the case. Could be you molded it crooked, or could just be dust. Take a credit card and slide around the edge of your screen carefully.
                              Other option is the controller is dying and it wont store calibration settings. Then it would work after calibration but slowly go away. Depending on how much time between it working and not working this might be it too.
                              Solution A is easy, B means you need a new touchscreen controller or overlay.
                              1.9in x 2.9in -- 47mm x 73mm
