2000 Dodge Durango: Need Suggestions
  • 2000 Dodge Durango: Need Suggestions
    Due to the frustration of dealing with a 1 1/2 din situation. I just purchased a Samsung Q1 UMPC which I would like to use for my CarPC touchscreen. I am planning on buying a dash mount I seen on Ebay. Also getting a new head unit with Bluetooth capability and USB input. The Samsung Q1 has Bluetooth onboard. I wanted to know if I purchased a head unit that is Bluetooth ready could I sync the two devices and play my music from my Mobile PC through the head unit through Bluetooth?
    I plan to run all my Music, GPS, and Videos through the Samsung Q1 with an external USB Passport harddrive for storage.
    I am open to all setup suggestions.
    The hardware will work as advertised, but it's important to note that the drivers for the devices are not necessarily there to allow all Bluetooth devices to connect to all other Bluetooth devices.
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
      If you're looking for mounts, I'd recommed looking at www.proclipusa.com or www.ram-mount.com. Both are good from what I hear. I use the proclip version and it's fantastic.
