i will finally take this sound card but..
  • i will finally take this sound card but..
    Hi
    i want to take this sound card (auzen xfi-prelude 7.1)
    http://www.cluboc.net/reviews/sound/...lude/index.asp
    but i also have this pc:
    http://store.mo-co-so.com/index.php?...roducts_id=179
    i ask the sellor to change my case by this one :
    http://store.mo-co-so.com/blog/?p=19
    so there's no problem with the space...
    but i want to know:
    Will the power suply has enought power for this card?(i also have a gps usb , a dvd usb, a touchsreen and a OCZ 30GB Core Series V2 Solid State Hard Drive , i will maybe have a usb wireless card later...and a usb wireless keyboard)
    i also want to know if this pci port will acccept the card without problems :P
    thanks for the help!
    i have choosen this card for its 5volt rms output!:P
    Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
    to the top
      did you inquire with mo co so?
      according to the link (above) that you provided us, you will have to wait till January 20 to get answers since the case you are referring to hasn't been released yet.
      Check out my CARPC: Project Diamond Plate
      Quick Reference:
      CPU Electrical Specs
      Power Supply Calculator
      Video Connections for newbies
      Temperature Converter
      Voltage Calculator
        yes but with the motherboard and the psu ...you cant say if the sound card will fit perfectly?
        the case they wil have the 20th will just be a case...with the same motherboard..
        this is the motherboard in the case :
        Product Specifications
        Processor ATOM 330 1.6GHz Dual Core 8 Watt CPU with 1Mb L2 cache
        Front Side Bus 533MHz
        Chipsets Intel 945GC Northbridge
        ICH7 South bridge
        Graphics Intel GMA 950
        System Memory 1x 240 pin DIMM socket for DDR2 533MHz/667MHz RAM
        Supports up to 2Gb
        IDE 1x ATX 100
        SATA 2x SATA 2.0 (3.0Mbps)
        USB 8 total USB 2.0 ports 4x Rear Panel / 4x internal headers
        LAN 1x 10/100/1000 Mbps
        Expansion Slots 1x 32 bit PCI
        Audio Realtek ALC662 High Definition audio codec
        Rear Panel I/O 2x Ps2 for mouse and keyboard
        1x VGA
        1x S-Video
        1x 10/100 LAN
        1x RS 232 COM
        1x Parallel Port
        4x USB 2.0 ports
        3x Audio: Line in, Line out, and Mic in
        Onboard I/O 4x USB 2.0 ports via pin headers
        1x Front panel audio header
        1x P4 CPU power connector
        1x 20 pin ATX
        1x Fan header
        1x PCI slot dont know if it is ok for my sound card :S
        BIOS Intel BIOS 4mb flash memory
        Monitoring and Management Power Management (Supports S3 standby)
        Fan Speed Control
        Wake on USB
        Wake on PCI
        Wake on LAN
        Wake on Keyboard
        Wake on Mouse
        Operating temperature 0°C - 50°C
        Form Factor Mini ITX 17cm x 17cm
        Also Included 1x IDE Cable
        1x Driver CD
        1x SATA Cable
        1x I/O Shield/Back Plate
        1x Quick Reference Guide
        and this is the psu :
        M2-ATX Smart Power Supply
        :http://www.mo-co-so.com/~photos/fanl...nlesscarpc.htm
          do not buy from this seller !
          chek that thread !!!!
          http://www.mp3car.com/vbulletin/gene...hat-peice.html
            From who, MoCoSo?..... I just bought a USB BT Dongle that Centrafuse recommended and it works awesome.
            1X Ainol Novo Flame Tab
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1X 7 inch motorized Screen
            1x Win 7 PC
              yeah all works fine for me too...but it seemms that they can sent you the wrong product ...when they want to save money or i dont know what.
                On the subject of the Mo-co-so store, I'd have to say that I have never been happier with any online purchase. I've hit a few bumps, but Chris smoothed them out quickly. I ordered my PC from him, it was missing something. One email sent, and a few days later I had the part in my mailbox. I had a small problem with the GPS antenna I ordered. Again, one email later and I found out I was setting the BAUD rate wrong. The guy seems to be pretty reasonable.
                I'm sorry that what went wrong in your transaction left a sour taste in your mouth. I do agree with you, in part, about what happened. You should have been notified if something else was being shipped. But I can assure you, if you gave him proper time to reply, you would have been more than happy with the options he would have offered.
                03 Accord Sedan CarPC
