Os ???
  • Os ???
    ok so im looking at starting my pc his weekend and im cusrious what is my best option to use for my os. I hear alot of ppl saying use nlite or tinyxp.
    I plan on having my hd radio, gps, winamp, vlc, and was planning on running RR for my front end.. So what would be my best option for running xp pro.
    Thanks for any input
    Just use a standard build of Windows XP to start. You don't necessarily need a stripped build of Windows for a CarPC.
      XP Pro is just fine. Boot up times are still good, and you dont have all the installation hassles of a stripped down install.
      1.9in x 2.9in -- 47mm x 73mm
        ok thanks for input..
          nLite is not an OS.
          It is a utility for making a Windows install disc to include drivers, applications, and stripping out unwanted components & services from Windows.
          TinyXP is just WindowsXP that has been stripped down.
          Frankly, I would do as others have suggested and go with a full install of WindowsXP. Too many TInyXP (or other stripped down variants) users are lacking services or components they need.
          How about the Wiki?
            To be fair, TinyXP isn't missing much. The people that are having problems went with the ultra stripped down version which doesn't even have the Windows system tools. I still debate how much better TinyXp is versus a normal build of Windows. The unattended install is nice, the service packs and updates already rolled in is nice. I'm still not convinced it really boots much faster though.
              The less that is stripped the less useful it really is. But you can make self installing dvd with updates and service packs for any full installation too.
                Your best bet if this is your first go-around, is to do a full XP install, then run the BlackViper service tweak (reg file)...there is also an undo file. This will help out quite a bit, as far as resources go...
                The biggest offenders are system restore and indexing services...
                http://www.blackviper.com/WinXP/registry.htm
                (Near the bottom are the files)
