OPUS DCX3.120 Help
  • OPUS DCX3.120 Help
    i recently bought the OPUS 120 watt DC-DC power Supply DCX3.120 and got everything going for the most park. There is a little green and white braided wire, i believe for power but I do know what im trying to connect it to. Other than that everything should work fine i hope
    It goes from J7 on the Opus to the power button header on your motherboard.
    How about the Wiki?
      alright but what am I looking for exactly? Is there anyway you could describe it or maybe even send a picture of where it should go?
        c'mon guy, you can't expect to be spoon fed everything. If you look at your motherboard manual, you can figure it out all by yourself. Most every motherboard is different, so there's no way someone can just show you a generic picture of where it goes. It hooks up to the same header that a normal power button would in a normal case.
        Tidder
        Try RevFE
          Have you ever opened up a computer to look at the connections that are made to the motherboard?
          Alternately, have you looked at the manual for your motherboard that indicates where the diagrams are that show you where to connect everything?
          This is where you need to start educating yourself, especially about the equipment you have or plan to use.
          How about the Wiki?
