noob question is 800MHZ c3 processor enough?
  • noob question is 800MHZ c3 processor enough?
    to run road runner? a 800MHz and 1GB of memory. all i need the pc is for nav and bod2 guages. is it enought to run it smoothly, also what will the booting time will be for that setup?
    I run a laptop with an 800 processor and it has no difficulty with rr and nav software. My boot time is about 20 seconds from ignition.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
      Hi
      i too have the c3 processor with 800MHZ and 1GB ram. I found it is bit slow.
      so i am running XPe now. While i put XP i felt very slow.
      Pon Saravanan
      My Car PC Setup
        It should be more than enough for XP, but my old 1ghz C3 was sluggish at running Centrafuse 2.0.
          I used a via EPIA 800 for the longest time. It'll run RoadRunner fairly well. Just make sure to turn off the extras like screen transitions.
          I was running RoadRunner, iGuidance, and cruising the interwebs decently with it.
          Booting time will vary depending on OS customization.
          Tidder
          Try RevFE
            I ran XP and Garmin Mobile PC. It was bit slow on rendering and loading maps.
            Now working on XPe 120 days trial. SO far so good. I will update if it is completely succcessful
            Pon Saravanan
            My Car PC Setup
              it's good enough for a starter project. but I feel you will want to upgrade the processor in the very near future.
              A simple solution is to read the software manufacturers system requirements, as there is no one right answer when asking about nav programs in general.
              Check out my CARPC: Project Diamond Plate
              Quick Reference:
              CPU Electrical Specs
              Power Supply Calculator
              Video Connections for newbies
              Temperature Converter
              Voltage Calculator
