how much power do I need?
  • how much power do I need?
    I am going to be purchasing a new alternator very soon
    my current alternator is only producing 90amps on a 2003 mitsubishi lancer. these are small cars and its hard to find alternators for them but I have managed to talk to a guy that said will do it for 400$ for a 200amp alternator that fits my exact car no modifications needed. I was wandering if 200amps would be too much. right now installed in the car I have 1 jbl 1200 watt amp and a fosgate 400watt amp and a 2 farad cap. my lights still dim. I bought another jbl 1200 watt amp to put 1 on each sub and will also be buying an optima yellow top. I was wandering is 200 amps is over-doing it for 3 amps. each jbl amp has 3 40amp fuses in them and the fosgate has 2 - 40amp fuses. Also I was reading something about a battery doing 75ah does that mean even though my alternator is producing 200amps / second that the optima yellow top can only deliver 75amp/second? Sorry if this is funny but im kind of newbish to this. Thanks for anyones help
    Everything you need to know can be found by clicking below
    Choosing a High Output Alternator
    Check out my CARPC: Project Diamond Plate
    Quick Reference:
    CPU Electrical Specs
    Power Supply Calculator
    Video Connections for newbies
    Temperature Converter
    Voltage Calculator
      sorry that it is sort of hard for me to understand but I think I have it right. the battery I am wanting to get has 75 amp hours. (optima yellowtop). so I divide the 75 / 2 which gives me 37.5
      then I will mutliply my current alternator by 40% which gives me 36 amps
      now I add my 36 amps + the 37.5 which equals 73.5 amps. therefore if I was to have a 200amp alternator I would have 126.5amps for the stereo. Correct me if I am wrong please.
      Even though I read all the information there, it still doesnt help me tell how much my stereo will need to operate. The link you gave me says 100amps for average stereo loads. I dont know if mine is below / above average. I appreciate the quick reply, im not completely stupid, I just dont wanna spend 400$ if I can buy a 160amp alternator for 200$... know what I mean.
        OK, here's the equation we need in order to calculate how much amperage you need at the alternator:
        Average Current Required to Supply Non-Stock Loads (A)
        50% of Total Battery Bank Capacity (B)
        (in Amp-Hours -- NOT cold cranking amps)
        Maximum Vehicle Electrical Load (C)
        (for vehicles, typically, 40% of max stock alternator output amps.)
        Min. Alternator Continuous Duty Output Amps (D)
        (At your planned operating speed)
        We need to figure out the values above for: (A) +(B) + (C)= (D)
        Since you're not online, I'll try to do this on my own...
        (A) Average Current Required to Supply Non-Stock Loads
        Let's see, this is what I have for your fused rating on all three of your amplifiers:
        Fosgate= 80a
        JBL= 120a x2 = 240a
        so the combined total is:320amps
        To get your average we must divide the combined total (320) by three, that equals to 106 Amps
        We have the answer for A, lets move on to B:
        (B) 50% of Total Battery Bank Capacity
        And you said you want one Optima Yellow Top with a 75Amp Hour rating
        so 50% of 75 is 37.5 (B)
        (I suggest on getting three batteries to = 225 Amp Hours, But we'll continue the equation with your planned purchase)
        B is done, now Let's work on C
        (C) To calculate your Maximum Vehicle Electrical Load which is typically 40% of the max stock alternator output amps.
        I am assuming your stock alternator is an 85 amp denso unit, correct?
        If so, then 40% of 85 amps is equal to
        34 Amps (C)
        A(105) + B(37.5) + C(34) = D 176 AMPS
        Yes, I hear you, your proposed plan will work fine with a 200 amp alternator with the Optima 75 Amp hour battery. Since you only require 176 amps you'll have a little head room to raise your volume a little past 30 percent while traveling.
        Now if you want to blast the music while the vehicle is not running. You might want to add two more 75AmpHour batteries, with a dash mounted voltage gauge, to be on the safe side.
        Quick Reference:
        Voltage Calculator
          I probably wont ever run the stereo when the car isnt on. Thank you very much for helping me, I can see how it can get frustrating exspecially when there are lots of new people and newbies n the forum. Another thing I am wandering is why you took 320 amps and divided by 3 to get 106, is the reason you divided by 3 is because each amp would be at 30% on the gains? I figured each amp would probably be at around 80% on the gains...
          I reread and you divide by 3 to get the "average" so since I will be getting a 200 amp alternator and be using 176 amps, I would have around 24 extra amps to play with to get alittle above average? so maybe 50% gains on all amps
