help needed motherboard wont fire up
  • help needed motherboard wont fire up
    im very new to all this and building my first pc, i have fitted my 12v psu and motherboard, i wanted to make sure these were working before i went any further, the psu definately works, but no life at the motherboard, should there be a connection from the psu to the motherboard that switches it on, apart from the main 20wire connector. here is a diagram
    Is the PSU to MB on/off switch connected? i don't see it..
    Also, does it need the P4 wire to be connected?
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      Yes, there should. Theres a header on your PSU that is equivalent to pressing the "ON" button on a computer case. When the PSU gets power, it knows to "press" that switch which turns your computer on.
      2001 Mustang Convertible Worklog
      Indigo Custom Frontend (Flash/Delphi)
      Blog
      Qube v1.3 Now Available at the mp3Car Store!!!!!!
      The simplest IO controller you'll ever use!
        do you know how i find out with connection it is on the motherboard
          It is usually a pair of pins sticking up. Short of having a diagram for the MB, follow the wires coming from the computer's on/off switch; you can also tap into those wires.
          OLD SYSTEM (DEAD)
          M2-ATX Power Supply
          Windows XP SP3
            Read the mothrboard's user manual.
            How about the Wiki?
              unfortunately i dont have a manual brought it off ebay
                Which motherboard do you have?
                If you cant DODGE em, RAM em.
                  Sorry, but that's decidedly weak.
                  You can download the manual for damn near any motherboard from the manufacturer's website.
                  All you have to do is look, and you'll find what you need.
                  How about the Wiki?
                    Hold tight, somebody is going to search the web, download the manual, read it, and make a special trip to connect the wire. Just hold on!
                    OLD SYSTEM (DEAD)
                    M2-ATX Power Supply
                    Windows XP SP3
                      somebody give that guy a mentos.
                      http://www.mp3car.com/vbulletin/show...ml#post1304561
                        chill out treetop, like i said im very new to all this, thanks for your help though guys, ive managed to sort that now sorry about having to be spoon fed.
                        next question is probably just as obvious as the last, when i fire it up now it beeps on and off none stop and there is nothing on the screen what so ever, basically there is no signal to the screen.
                          Look for the name of your motherboard and search for that manual. Additionally, here is an example of me searching the word "Beep Codes" Here, in google
                            hiya yeah ive got the manual did that ages ago but it doesnt tell me alot. The motherboard is a via epia m-9000 unfortunately i never got given any drivers, but withought them i should still be able to see something on the screen
