Slimline sata cable conecctions
  • Slimline sata cable conecctions
    Hi,
    i need power conecctors schema off this cable in attachment
    on which conecctor power is?
    sorry for my bad english
    The red wire is +5v and the black is ground. The flat cable is the SATA cable. So you connect red-to-red and black-to-black using an available power connector from your PSU.
      this looks like it is for a slimline sata drive as there are no 3v or 12v lines on the cable
        I need marked connections i dont have this cable, need this conecction to build it
          1 Device Present
          2–3 5 V
          4 Manufacturing Diagnostic
          5–6 Ground
          http://en.wikipedia.org/wiki/Serial_ATA
          edit: i dont know which side is pin 1 but it would probally be the key side
          | 1 2 3 4 5 6|
          |_-----------|
            ohhhhh thnx
              Hello,
              I plan to build the power cable, too. Who knows how I have to connect:
              pin 1 Device Present
              and
              pin 4 Manufacturing Diagnostic
              mayby pin 1 with 5V and pin 4 with ground ???
              Yours faithfully
              Chris
              Originally posted by Virac View Post
              1 Device Present
              2–3 5 V
              5–6 Ground
              | 1 2 3 4 5 6|
              |_-----------|
                No, that's probably a quick way to fry your drive. DO NOT connect pin 1 or pin 4 to anything. Pin 1 doesn't say anything about 5v, and pin 4 says nothing about ground, why would you even think this is correct?
                Virac is correct, pin 1 is the key-side.
                Tidder
                Try RevFE
