Cheap liquid cooling
  • Cheap liquid cooling
    Okay, so I am building a little box that my computer will sit on in my trunk ( about an inch high) to put some radial fans, blowing cool air from the sides of the box to the underside of the computer.
    But I am wondering is there a cheap liquid cooling solution, that is also rather small, to just help out with cooling. I am not worried about the physical aspects (size and such) but just what it can do.
    If you have any suggestions that would be great!
    My carputer is water cooled...though I wouldn't call it 'cheap'.
      well I have a vroom pc case. So like the cooling wouldn't be as easy to do. and I'd only need a system that could handle the cpu and possibly a little more...
        Very nice system, man.
        Clean and well executed.
        Which way do you have the rad fans blowing?
        Also, do you have something to cover it up so that stuff can be piled on top, or is that space lost for cargo use?
        As for doing water cooling in a small case- tricky, but possible.
        There ARE some very small systems around, but I'm not sure that even THEY would fit in a case intended for carpc use. And the performance is less than stellar (without modifications!) But if you have room to mount a pump and rad outside the case all you really need is a compact water block or two, and a bit of creativity.
          Considering the fact that liquid & electronics don't play nice together, do you really want to cheap out on hardware for liquid cooling and risk destroying the PC components?
          How about the Wiki?
            The radiator and such would be outside the pc. Just a tube going into it. Which I would make sure has an exelent seal.
              Thanks...
              The fans on the rad blow in...the other fans are for the parking lot
              There is a speaker cloth covered piece that covers the PC, yes...but not the amps.
                First of all, there will be at least one water block mounted to the CPU. Depending on the setup, you may have additional waterblocks on the motherboard chipset and/or GPU as well.
                There is a reason quality liquid cooling components are pricey. They are well engineered and manufactured with precision.
                In order to make them less expensive, corners are cut somewhere, possibly with quality.
                I'm not you, I know.
                But if it were me, I wouldn't want to go with budget water cooling for any PC, let alone one in the car. If that cheap component winds up being defective out of the box, you are risking destroying that hardware.
                If that hardware is in your car, you're risking an electrical hazard and a hire hazard.
                Do what you're going to do. This is just food for thought.
                How about the Wiki?
                  WuNgUn- well done indeed. I have seen (and done myself) some water cooled desktops that weren't as well done based on appearances.
                  My only other comment is to ask if you ever tried the fans the other way: pulling into the computer/mobo airspace will get you the best H2O block temps, but will increase mobo temps a bit too. The other way will reverse that. I have used both in different systems, depending on temps and how the systems ran.
                  DarquePervert makes good points, no doubt: a cheaply made part IS far more likely to fail, and I have seen some cheap crap over the years.
                  But there used to be inexpensive yet good parts around too; performance was not as good as a rule, but except for heavily overclocked and/or modded machines some of those parts can do pretty well.
                  For a cheap system, you may do well looking at the "Clearance" sections of the water cooling vendor sites, and perhaps some of the better modding/hardware sites.
                  You would need a well-made block and decent pump, and something sufficient for a radiator.
                  Some possible stuff:
                  http://www.directron.com/zmwb2.html $10 cpu block
                  http://www.directron.com/xtreme1.html $33 rad (or buy a cheap heater core and solder barbs on it for about $20)
                  http://www.jab-tech.com/Swiftech-MCP...p-pr-3510.html $65 pump (a decent 12v pump is hard to find and is something you don't want to skimp on.)
                  http://www.dtekcustoms.com/index.asp...ROD&ProdID=188 another pump for $45... but I haven't needed a pump for a while and don't know how good it is.
                  Add a few bucks for tubing and maybe fittings and you might be able to do it pretty cheap while still using pretty good parts.
                    My desktop and car both draw in cool outside air and exhaust it into the case...I've never tried it in reverse...is there any benefit?
                      The "benefit" is that the radiator don't get cloggy with dust.
                      The ovbious drawback is that the cooling efficiency is reduced, since you then have hotter air flowing through the radiator then you got while using external air.
                      I have used both setups.... For a normal computer, drawing air from the case is OK... but for an extreem OCed computer... it's a big drawback...
                        Reducing clogs is one plus.
                        The other, as I said earlier, is reducing the temps of NON-watercooled components in the case.
                        To clarify:
                        When you pull cool air through the radiator and into the case, you are using warmed-up air to cool the other stuff IN the case.
                        *Pro- best cpu/block temp
                        *Con- case cooling air is already warmed up by the rad, so slightly higher mobo/case temps; more dust in the rad
                        When you pull air from the case and exhaust it through the rad the case air is slightly cooler, but cpu/block temps are a bit higher
                        *Pro- better cooling for non water cooled components (anything in the case that is NOT water cooled); less dust in the rad
                        *Con- higher cpu/block temps
                        I have used both methods for different systems over the years and neither is "better" in general. Depending on just what you need to cool the most, one or the other may work better in a given system, and the only way to be certain is to test them.
                        The absolute BEST way to get the maximum cooling is to have the radiator air and case air completely separate, but this requires either more room in the case or an external radiator. Not really required unless you are overclocking/overvolting the daylights out of a system or have extremely high ambient temps.
                        Really I was just curious to see if you had tried and which worked better.
