m2 -ATX problem/Need a momentary switch that works with voltage...
  • m2 -ATX problem/Need a momentary switch that works with voltage...
    So Here's my delima. I think the m2-atm (used) I got, has an issue with the ignition switch. It does not come on with the car, and I've test the wires for connectivity, as well as voltage.
    Before I go any further. I was not given a jumper with it, there are jumper settings, and right now based on the manual I am at P0. It recommends P1. with a jumper... but I don't have that, could that be why?
    If that is not why, the computer only comes on when I physically connect the wires from the parallel on/off switch part on the m2-atx...
    So it should come on with ignition. Only comes on with the m2-atx parallel switch cables... and that is regardless if it has ignition power or not.
    So my question is, is there a momentary switch that will a) switch on when it first gets voltage, and b) switch when it loses voltage. As to simulate the m2-atx standard function, only between the parallel on/off switch.
    Radio Shack has jumpers you can buy in a little baggie.
    Google (or Bing) for the manual and look up what jumper position you want to use.
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D/i7 still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
      they don't actually. Or least the ones around me don't... they suck...
      I have the manual, but it doesn't say whether or not the ingition wire does anything on p0 (w/o any jumpers) I guess the simple solution is get a paper clip and temporarily connect the pins. But I figured I ask first because I've put it all back in the house. And, that may not be the answer anyway..
        I think p0 is dumb-psu mode. IGN would not do anything.
        Make sure you read the manual before you go spend money on switches that you might not need. Jumpers should be found at any electronics store near you. If not, theyre a few pennies online.
        2001 Mustang Convertible Worklog
        Indigo Custom Frontend (Flash/Delphi)
        Blog
        Qube v1.3 Now Available at the mp3Car Store!!!!!!
        The simplest IO controller you'll ever use!
          Back in the day Radio Shack was awesome, but now, all they do is push phones, SAT Radio, and Tvs on people. They are no longer really hobbiest friendly. I am sure you have an old MoBo laying around that has a jumper on it. Maybe even a old broken CD ROM or HDD that has one?
          I think its dumb mode also. Find a jumper and all should be good.
          1X Ainol Novo Flame Tab
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1X 7 inch motorized Screen
          1x Win 7 PC
            You are looking in the grey set of drawers with the part pictures on the front, like mechanics toolboxes right ? They are not on the wall, even the crappy little RS in the mall had them?
              yes... I looked like I said. They didn't have any
                Might be in the computer section
                Model: 276-1512
                http://www.radioshack.com/product/in...ductId=2103807
                  Okay. so I just borrowed a jumper out of another computer. Still didn't work.
                  I've got all the wires plugged in and the ignition line IS giving off 13 volts. When I don't use the ignition line, and just connect the jumper pins where a normal on/off switch on a computer would go, it powers on just like it should. So does anyone have any ideas on what's wrong with this thing?
                    What about constant power? Is the PSU always getting power upon ignition and turning off?
                    4X MK808b
                    3x Perixx Touchpads
                    3x 7 inch Screens
                    1x Win 7 PC
                      What do you mean? It is hooked into the battery...
                        What gauge wire. Could it be maybe you have the constant and ignition mixed up?
                        4X MK808b
                        3x Perixx Touchpads
                        3x 7 inch Screens
                        1x Win 7 PC
                          ignition is 18 gauge, the battery is 10 or 12 gauge i don't remember. but no i did not mix them up
                            what mobo are you using? is it possible that you're not hooking it up to the mobo right?
                              No. I've installed windows and everything on it. I've made sure it works. It works perfectly when I connect the power jumper on the m2-atx. (the parallel one that is) but not with the ignition.
