Infiniti g35 Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen?
  • Infiniti g35 Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen?
    I just have a question before i purchase.
    Will the Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen, fit on a 2004 Jdm Infiniti G35 Double Din Conversion Kit?
    i beleive that it would work, but there might be some modifications to get it to fit perfectly.
    also, look up bybyte-- they also make a double din frame, and it might be cheaper, and easier on the wallet if you need to modify it.
    next project? subaru brz
    carpc undecided
      I have a 2005 G35 so my jdm dd kit is a little different. All I can say is that the bybyte dd frame fit with a little bit of modification to make it fit flush. I can't really say anything for that dd kit.
        Yes it will fit. But if you want it to fit flush. I would fabricate the entire double din kit w/ the Lilliput bezel. So it would look seamless & OEM
        (I own a 03 G35 coupe, so I have the same idea)
