Need help with a 4 channel amp | chA is louder than chB
  • Need help with a 4 channel amp | chA is louder than chB
    Hello,
    I just have few quick questions about this amplifier I got from a friend.
    Since I don't have a manual, I thought i would ask here.
    Here is my problem:
    I've connected the amp just like I have my other amp connected and when I connect a sub to chA its moving just a little bit (its only 40 watts). So, what I wanted to do is to bridge chA and chB to get 80 watts. The problem is that when I connect them, it doesn't increase the power. The sub seems to be moving the exact same way as it was on chA only. Then I connected the sub to chB only and I can barely hear the sub, does this mean that channel B is blown or not working? OR Can I somehow adjust it or something?
    It looks like this:
    Free Microsoft Points & Free WoW Time Cards
    adjust the gains?
    do you have both RCA inputs connected? some amps need both, even in bridged mode
    MacMini in an Alfa? - Why not!
      Originally posted by pulsarsimon View Post
      adjust the gains?
      well, it only has 1 pair of rca connected, my HU only has 2 outs. Should i get a splitter or something?
        might be the problem.
        did you check the manual for the amp?
          no, i don't have a manual. I got this amp from a friend.
          I'll try a splitter and see if it works, thanks
            what amp is that? what sub are you trying to use? it looks like a pioneer 300 watt, 4 channel, which might not be enough to power sub (i beleive that the specs are around 75 watts max per channel)...
            next project? subaru brz
            carpc undecided
              You are correct, it is a pioneer 300 watt, 4 channel. The problem is that i get the same amount of power from 1 channel as from 2 (bridged)
                waht are the gains set to?
                carpc undecided
                  Both are set to max. (i think, im gonna go check)
