newbie needs help with powering of AOpen DE965-HG Digital Engine System
  • newbie needs help with powering of AOpen DE965-HG Digital Engine System
    Hello im new to the carputer world, im looking for help powering up (AOpen DE965-HG) it came with a power cord/adapter. This carputer came with a round power cord plug how would i wire this up to the car, i want to be able to have the intelligent startup and shutdown feature. Right now i have this system running off a power inverter but don't like using it like this due to having to do a manual startup and shutdown.
    Here is a pic of the back of the carputer, the power if the round plug to the bottom left side.
    THANKS FOR ANY HELP.
    Ross
    Look at the power brick that came with it. There should be a label on it that lists DC Output Voltage.
    Once you determine that, then an appropriate power supply can be chosen.
    Chances are, it requires 12vDC or 19vDC. In either case, a Carnetix would work.
    I also suggest reading the FAQs: http://www.mp3car.com/vbulletin/advfaq.php
    All this informaton is located there for you to locate.
      Thanks DarquePevert, I checked its a 19volt power brick. ok so now I have a better idea I'm thinking of getting the carnetix cnx 1900. now if I'm correct the only other thing would be getting the aopen power pack wiring? I'm I correct? If yes that is all the help and thanks the after your help and reviewing the FAQ again I got a better understanding.
