Possible to hook up a carpc to a nav unit?
  • Possible to hook up a carpc to a nav unit?
    it would be possible to hook up a carpc to an existing Kenwood nav unit(DNX5120) and use the touch screen to control the carpc?
    Yes it is possible to connect a carpc to a nav unit, but not to use the touch screen, or have readable text.
    Use of the touch screen requires that you reverse-engineer the kenwood touch controller to tap into it,but then you sill have a problem with it possibly sending a command to both thenav unit and the carpc...
    Unless your navunit has a VGA input, you will need to use a composite input and a vga-to-composite adater to get it to work, and even then you will lose clarity of the image due to the adapters..
    next project? subaru brz
    carpc undecided
      Search on terms "OEM screen" or "nav unit" or check the FAQs.
      Want to:
