Barebone External PSU help
  • Barebone External PSU help
    I'm just getting into this carputer scene. Im lookin at
    http://www.newegg.com/Product/Produc...82E16856167032
    to use as my computer. I noticed that it has an external psu, so my question to you is how do I go about getting a startup/shutdown controller for it? I know there is laptop controllers out there but i wasn't sure if it word work the same way for a desktop.
    you would need to use a laptop-type power adapter to plug into the system(check power requirements of unit, and the power supply you want to use), and then should be able to use it normally-- ie: the controller would then power the computer on/off using the power button
      Also, if you're buying a new computer, have you looked at the systems built specifically for a car, such as those in the mp3car store, and those at mo-co-so.com? They come with an intelligent startup/shutdown controller and power supply already.
      Edit: Just noticed only some of the systems in the mp3car store come with a vehicle power supply. The others have it as an add-on option.
