What power supply to use with this
  • What power supply to use with this
    I am thinking of upgrading from a double din thing my brother bought for me a while ago to something a little better.
    Was think of matching a Preassembled Black Double Din LCD Frame with a ZOTAC MAG HD-ND01 mini pc,
    but was wondering what type of power supply to use with it, either an inverter under the passenger seat or go with one of the power supplies off this site.
    The zotac spec sheet has the power input at 19v DC, would the power supplies on this site be able to handle that or will i be stuck with an inverter?
    Thanks for any help
    Lab
    You can try one of these. It does go up to 19V, only thing will be if it has the proper connector. Can't beat it for the price. I keep one in the car in case I need to power a friend's laptop or anything else.
      or you can check for the carnetix unit in the mp3car store.
        would that be enough to power the pc and the lcd or should i go for the Carnetix CNX P2140 185W one to be sure i have enough juice to run both?
          the only thing that worries me is that the 2140 outputs 18.5v instead of 19, so depending on the board, it might not like it.
          i would go with the 1900 version because it says that it outputs 19v.
            The P2140 and P1900 both output the same voltages.
              so will the P2140 work with the zotac mag??
                yes, it should work fine.
