Blue screen
  • Blue screen
    Hello, I have car dvd head unit InnovateK 868TS everything works fine on the screen. Until I put in a dvd to play, all I get is a blue screen with sound. I have the wire hooked up to the breake. Anyone know what is wrong with my head unit. Thanks
    If you're sure everything is hooked up correctly, first thing I would do would probably be contact the manufacturer.
    Tidder
    Try RevFE
      If the headunit has a reset feature or a sequence of buttons to press in order to reset it, find out how to do it and reset it. This might fix it. Usually the manual will contain the reset procedure.
      If that doesn't work, pull your radio fuse and then put it back in. That should cause it to lose memory and maybe it will work when you put the fuse back.
      2007 Camry Altise In-dash Car PC
        the brake wire should be hooked to ground if you want to watch dvd while the car is in drive also i found that those units are not very good and have a real wonky dvd drive in them. i found only original dvd/cd's or burnt ones on very slow recording speed (2x for example) hope this helps SNO
          I know its hooked up correctly casue it use to work, then one day I got a blue screen when i put a dvd in it. For the radio I could see everything on the screen. Thx
            I tend to agree with Snowtwistr.
            Have you tried an audio CD? Does it play at all? Do you see the controls on the screen? (play, pause, next track, etc.)
            If no CD works, the CD drive might be on its way out. You could try using a cleaning CD/DVD in the hope that it's just dusty inside.
              I could play audio CD and it has sound. I see the controls on the screen for radio and dvd (play, pause, next track, etc.) I also use original dvd. Thx
                You used to play DVDs on it or this is the first time trying? I think you have the wire hooked up wrong.
                2001 Mustang Convertible Worklog
                Indigo Custom Frontend (Flash/Delphi)
                Blog
                Qube v1.3 Now Available at the mp3Car Store!!!!!!
                The simplest IO controller you'll ever use!
                  I used dvd for before and it work, then oneday i got the blue screen, so i know its hooked up right cause it use to work..
                    Double check that the wire didn't come lose or short out.
                    openMobile - An open source C# Front End (why choose openMobile?)
                    - Always Recruiting Developers -
                    Like what you see? Donations are always welcome
                      Ill Double check the wire. Thx
