Temporarily using inverter - is anything going to blow?
  • Temporarily using inverter - is anything going to blow?
    Hi all - I've got my CarPC up and running... its an ugly, inefficient mess of wires right now but it was still a thrill when it actually worked.
    Right now I have an inverter powering my netbook and a USB hub. I just want to be sure its sufficient and I'm a complete nipple when it comes to electrical uh... stuff.
    Inverter:
    Input 12V dc, 16A
    Output 120V ac 60Hz
    1.5A 150W (continuous), 175W (assuming max?)
    Fuse 20A/32V
    Netbook: (HP Mini 1033NR in case it matters)
    Input 100-240V 1A 50-60Hz
    Output 19V==1.58A 30W
    USB Hub:
    Input 100-240V ac 0.5A 30VA
    Output +5V==2.5A
    Am I correct in assuming that since the inverter can handle 1.5A I'm basically maxed out but safe?
    Also, I have this inverter plugged in to my car's accessory plug along with an XM Direct unit (12V dc). Any danger of overloading the accessory?
    I am planning on getting a more permanent power supply soon, this is all temporary. I'm thinking a Carnetix P1900. If anyone wants to offer any thoughts on this please feel free.
    Thanks,
    Matt
    i think you should be ok.
    the main reason that none likes inverters is that they are messy-- you are converting dc to ac, back to dc.. and the fact that the current dc-dc options offer shutdown controllers with them, it makes dc-dc's a cheaper, and easier option to use...
    next project? subaru brz
    carpc undecided
      You should be okay. I don't think you are anywhere near maxed, actually.
      Want to:
