what is compatible with M3-ATX
  • what is compatible with M3-ATX
    im looking for buy or custom build a car PC and i just need to know what type of motherboard or whatever setup i need that is compatible with the m3-atx power supply. i would greatly appreciate it if someone could help me out or point me in the right direction.
    thank you
    It's all a matter of power draw.
    I wouldn't use an M3 with anything more powerful than an Atom-based setup, and even then limiting the number of peripherals is a smart idea.
    How about the Wiki?
      would an m4-atx be alot better?
        What are the pieces you think you will have for your carpc setup?
        I have the m3-atx and have had no problems. I have an atom based cpu and an SSD which both draw very little power.
        Also, I have many usb devices and power my screen with the m3-atx.
          what i am thinking is....
          Intel DG45FC motherboard or ZOTAC GeForce 9300-ITX WiFi
          intel core 2 duo e4___ probably if i can find a cheap enough one
          2gb 800mhz ram
          prob a 80 gb 2.5" hd
          m4-atx (probably need this for the higher wattage correct?)
          usb dvd
          wifi ( whats better usb or pci wifi card)
          bluetooth for handsfee calling
          gps antenna
          and possibly a tv tuner?
          zenarc 700tsv screen (already got one from ebay for $80 without any cables which i have to buy)
          am i missing anything?... whatever input i can get is great..!!
            Methinks someone needs to start perusing the FAQs.
            Check the link in my sig.
            How about the Wiki?
