Onboard DC-DC PSU
  • Onboard DC-DC PSU
    I was looking at a Dual core Atom + Ion combo as a carputer, and I noticed it came with a 40w onboard DC-DC PSU. Does this mean I can't set it up for a car?
    It requires regulated 12v and your vehicle's electrical system doesn't provide regulated 12v.
    Can you use the board? Sure, with a regulator.
    How about the Wiki?
      slight correction-- there is no link to the product your talking about, so i can't be sure that it has a on-board 12 volt dc-dc. many atom boards have a 19v power adapter, which would have different in-car power supply requirements.
      saying it uses dc-dc power is like asking why your Ford won't start-- there are many variations within the category, and all of them can have different solutions.
      next project? subaru brz
      carpc undecided
        http://www.newegg.com/Product/Produc...82E16813500027 is the product I am looking at.
          doesn't say the input voltage on the details page.
          you need atleast 9-16. or you will probably burn the dc-dc converter when you start te car
          (car running is13.8 volts or higher)
          Car system in the making:
          dualcore atom
          M2 atx psu
          screen??
            The board requires regulated 19v.
            Your vehicle can't output that voltage, so look at a Carnetix.
            How about the Wiki?
              Now much of a electrical junky, but which carnetix should I be looking at? P1900?
                the faq's cover how to pick the correct power supply (link in darques sig)
                carpc undecided
