25 inch lcd computer monitor
  • 25 inch lcd computer monitor
    can i install this in my expediton and what bout the cold weather in the mo will it still work help please
    Sure.
    Tidder
    Try RevFE
      so the cold weather will not be problem
        you realize that there are thousands, if not millions of models of monitors in use all over the world, many of them having vastly different powering schemes, components, and connections? there is a way to get all of them to work in a car, but there are almost as many ways to get each one to work as there are monitors..
        you need to be more specific(we don't know what your using)
        next project? subaru brz
        carpc undecided
          westing house model lcm 19w4
            according to what i can find on that monitor-- it requires a ac input, which means that you need to use a inverter-- this can be bad, as some inverters can introduce more problems then it is worth.
            the cold weather can be a factor for the ccd tubes-- it will only lengthen the time it takes them to warm up and emit light.
            carpc undecided
              thanks that all i needed to know
