Types/Names of Cables/Adapters
  • Types/Names of Cables/Adapters
    Ok, I have taken apart my laptop and saw the motherboard, and the types of connecters on it. I want to remove the touchpad mouse (or purchase another one simply to keep the laptop case intact), and mount it in the center console. To do this, I want/need to find out where I can get extensions for the cables used to connect this, and a few other items I wish to mount remotely.
    The links I am posting are from my phone, I hope they can be viewed, if not I will fix when I get home.
    Touchpad Mouse (attached to palmrest, easily removed):
    http://item.mobileweb.ebay.com/viewi...id=48610106253
    http://item.mobileweb.ebay.com/viewi...id=72971107715
    USBs:
    http://item.mobileweb.ebay.com/viewi...id=01279283951
    Power Button/Indicator Strips (I believe also attached to palmrest):
    http://item.mobileweb.ebay.com/viewi...id=31323551035
    So again, I need to find the type of connectors (names... I re-assembled the laptop after I THOUGHT I had taken pictures of them *facepalm*), and where I can get long lengths (if they make them). Some places I've only found up to 24" for similar cables, not sure if they're the correct ones though...
    Thanks in advance everyone!
    As of 4-10-14
    CarPC Progress: 60%+ Starting from scratch with old laptop. Trying to figure out how to get all the programs I want/need for RideRunner!
    My Build/Install Thread
    i would recommend to stay away from modifying any active internal components of the laptop. many times, the max length of the cables you can find is as long as the data can reliably travel..
    usb is a great alternative-- it is speced for around 15 feet, so works great in the car- environment..
    so with that in mind:
    usb touchpad:
    http://www.amazon.com/Adesso-Touchpa.../dp/B0007T27BE
    and then a usb splitter of any sort should be fine as well..
    next project? subaru brz
    carpc undecided
