M2 ATX help with J9 pin and its location on M10000 MB?
  • M2 ATX help with J9 pin and its location on M10000 MB?
    Does anyone have any ideas?
    I have Batt posi and ground connection to the correct pins on the M2 and the jumper setting set to A.
    I have NO idea where the J9 pin locates to on the MB and where the MB on switch jumper goes to on the M2 ATX? At present Im putting the J9 pin to the on switch pins on the MB and the on switch pin to to J8 but am getting nothing.
    Ive checked ll the fuses and they are all fine.
    Any suggestions?
    http://resources.mini-box.com/online...-HV-manual.pdf
    J8 goes to the motherboard connection where you would normally plug the case power switch into
    The case switch plugs into J9 on the power supply
    You also need a signal wire connected to the power supply not just + and -
    Read the manual
    My CarPC Mitsubishi Lancer Evolution IX MR
      Can I splice the signal wire into the wire connected to the battery +?
        you dont want to do that unless your just testing it
        you want to splice it into the accessory wire or anything that has no power when the car is off but has power when the key is turn to on or acc
        then you set the jumper on your power supply to signal a off switch when you take the keys out and a hard shut off depending on what you want
        its all in the manual
          Worked a treat mate. Just linked up the signal wire and it worked!
          Thanks!!
            have you encountered a problem with J6 i cant get mine to output a signal?
